Page 5 of 5 1 2 3 4 5
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2930850
06/07/21 12:03 PM
06/07/21 12:03 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
More pics from Thunder Hill
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2930852
06/07/21 12:04 PM
06/07/21 12:04 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
Last set of pictures from Thunder Hill
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2930938
06/07/21 03:34 PM
06/07/21 03:34 PM
Trumussia
jcc Offline
jcc  Offline
Trumussia
That chassis set with the enclosed pics and estimated speeds, looks to be a very well sorted out package. up
Car to share any of your set-up specs?
If you can't dazzle them with diamonds, don't waste your time, because nothing will
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2930989
06/07/21 05:12 PM
06/07/21 05:12 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Careful, your face may freeze with that smile on it. Looks like it handles pretty well.
What size rear tire are you running?
Re: Picture Thread - Track Racing Mopars! [Re: jcc] #2930998
06/07/21 05:51 PM
06/07/21 05:51 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
Setup is pretty simple and cheap. Stock front suspension with Hotchkis 1.1 torsions and a Summit brand 1 1/8 sway bar. I did get a proper alignment with -1.0 Camber / 3.5 Caster / and toe'd in just a bit. Rear is HD springs, 1.0" blocks, and a 7/8" Summit rear sway set in the middle. I did swap to disc's in the front with EBC Yellows, but the rear still has the 11" drums. Added brake cooling too. The ride height is down from stock but I don't remeber the exact drop. Its super predictable and well manered.
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Picture Thread - Track Racing Mopars! [Re: gzig5] #2930999
06/07/21 05:53 PM
06/07/21 05:53 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
Here's my tire wheel setup
Front Rim: 15x8, 4.5 bs
Front Tire: 245/60R15
Rear Rim: 15x10, 5.5 bs
Rear Tire: 295/50R15
These tires are roughly 26.5 in diameter front and rear for balance. I studied tire sizes over and over again and compromised with this setup to be safe. The tires are Mickey Thompson's Sportsman S/T's which have a treadwear rating of 440.
.......And Yes, I'm still smiling grin
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2931047
06/07/21 07:40 PM
06/07/21 07:40 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Gotta love the bowtie having a view of your tail lights.
Carl Kessel
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2931113
06/07/21 10:45 PM
06/07/21 10:45 PM
Trumussia
jcc Offline
jcc  Offline
Trumussia
Setup is pretty simple and cheap. Stock front suspension with Hotchkis 1.1 torsions and a Summit brand 1 1/8 sway bar. I did get a proper alignment with -1.0 Camber / 3.5 Caster / and toe'd in just a bit. Rear is HD springs, 1.0" blocks, and a 3/4" Summit rear sway set in the middle. I did swap to disc's in the front with EBC Yellows, but the rear still has the 11" drums. Added brake cooling too. The ride height is down from stock but I don't remeber the exact drop. Its super predictable and well manered.
Well that is as well balanced as the car looks. thumbs
Might as well ask what your drive train is.
Re: Picture Thread - Track Racing Mopars! [Re: jcc] #2931133
06/07/21 11:43 PM
06/07/21 11:43 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
Thanks, It really is a happy car. Nice thing is the car can go back to stock if I ever want to go back down that road.
Motor is a low compression 440 with a 6 pack. No bogging in the corners. 727 trans that unfortunately gets hot on very hot days but I’m working that out. 8 3/4 rear with 3:23’s. Typically gets into the mid 4K RPMs in the main straight. Best part of the car....still has the bench seat and factory seat belts. up
1969 Superbee 440-6
2000 Jeep TJ
2019 Ram 2500 CTD
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2931189
06/08/21 09:43 AM
06/08/21 09:43 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Looks like a lot of fun MoparMike23! And on a bench seat no less.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2932235
06/11/21 10:45 AM
06/11/21 10:45 AM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Man, how fun.. That shot of you with oversteer looks like a blast.. !
- Art
1965 Satellite hardtop 361/2bbl, console 727, open 2.76
1967 Satellite convert 383/4bbl, column 727, open 3.23
1975 Maserati Bora, US spec 4.9L DOHC hemi V8, 5-spd ZF man
1977 Maserati Khamsin, Euro spec 4.9L DOHC hemi V8, 5-spd ZF man
1982 Alfa Romeo GTV6, 2.5L SOHC hemi V6, 5-spd man transaxle
2007 Aston Martin DB9, 6.0L DOHC V12, 6spd man transaxle
Re: Picture Thread - Track Racing Mopars! [Re: MoparMike23] #2933219
06/14/21 02:03 PM
06/14/21 02:03 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Nice pics... lots of fun!
