Pat, As everyone else has said extremely impressive work and work environment, the time you take to photograph and document the build is equally as impressive.
Its a real shame that Photobucket blurs out all the previous pictures
Couple questions:
1) With all of those lines and respective parts did you do a prefit prior to paint and body work or are you fabricating and installing all as you go?
2) on the vinyl roof install, i understand the center panel install but when you move to the side panels, Do you have any help, someone holding it up on one end? getting that wide a panel over an arched roof section and not touch the sail panel is a magic trick.
Henry
