Page 4 of 7 1 2 3 4 5 6 7
Re: Andy, your 470/270TF indy 440-3 results [Re: Thumperdart] #2715683
11/14/19 12:41 PM
11/14/19 12:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Yeh....... big motors don’t rev whistling
Yes..... it’s 1005ci........ making solidly over 2hp/ci
Re: Andy, your 470/270TF indy 440-3 results [Re: second 70] #2715696
11/14/19 01:02 PM
11/14/19 01:02 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
My mistake, but yeah I forgot about the 302. Another bad ass short stroke motor..
Re: Andy, your 470/270TF indy 440-3 results [Re: Thumperdart] #2715698
11/14/19 01:05 PM
11/14/19 01:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
how come so many 500+ ci motors can't get into the 9.70's?
I take it from your question that all 470’s must be runnng 9.70’s then.
Or at the very least that more 470’s are running 9.70’s or quicker than people with motors that are 500” or bigger.
If the 470 is so much more efficient than the 511, and efficiency is in fact the key to making more power....... then it just stands to reason that keeping it at 400” would be even more efficient....... less friction from better rod ratio....... you’d make even more power!!!
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715700
11/14/19 01:07 PM
11/14/19 01:07 PM
PA
Harry's Taxi 2 Offline
PA
Originally Posted by fast68plymouth
I always get a chuckle out the “cubes don’t matter” arguments.
If that were the case, then why is it in pretty much any racing series or class that has a cube limit........basically has the entire field running the max allowed?
Take NHRA Pro Stock.......bump the limit to 550ci.
No one that stayed at 500” would be competitive in a very short amount of time.
Having a combination be more “efficient” isn’t the same thing as making more “power”.
A 470 making 700hp is 1.489hp/ci
A 511 making 735hp is less efficient at 1.438hp/ci....... but it’s still 35hp more.
As for the 4.25 stroke/6.535 thing being some sort of hurdle to overcome........
This is one of their budget friendly combos:
https://www.shafiroff.com/chevy-drag-race-engine-sportsman/565-big-block-drag-race.php
Here’s another one....... more hp, more rpm...... same stroke and rod length:
https://www.shafiroff.com/chevy-drag-race-engine-pro/565-big-block-drag-race.ph
The rod ratio for a 6.535 rod and a 4.25 stroke is 1.53....... same as a stock 454 or 502 Chevy.
Shafiroff also sells a 440” small block with a 6.00 rod and a 4.00 crank, which has a slightly poorer rod ratio of 1.50...... that one makes 950hp.
Peak tq @6800....... peak hp @8100.
Have you found that the same cubic inches with a lesser r/s ratio require more cylinder head flow and/or more cam timing to peak at the same rpm?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715702
11/14/19 01:10 PM
11/14/19 01:10 PM
Mt Morris Michigan
Mt Morris Michigan
I wouldn't say long stroke motors cant rev . We know otherwise. It just seems short stroke motors can do it with ease. The problem with the parasitic losses in the longer stroke motors is that they cant be seen and cant be measured, so some dont believe they are there. There is an article over on Rerer&Morrison about this and I have no reason to not believe it .
Re: Andy, your 470/270TF indy 440-3 results [Re: Harry's Taxi 2] #2715709
11/14/19 01:15 PM
11/14/19 01:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Look at it in the most simple of terms......
440 vs 383.
Both running 10:1 Cr, ootb rpm heads, rpm intake manifold, 850 carb, 1-7/8” headers, MP 509 cam, same rockers.
Which wins that battle on the dyno and at the track in a 3500lb street/strip car?
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715711
11/14/19 01:19 PM
11/14/19 01:19 PM
440 vs 383.
whistling stirthepot devil
KISS work
Re: Andy, your 470/270TF indy 440-3 results [Re: Cab_Burge] #2715717
11/14/19 01:35 PM
11/14/19 01:35 PM
an8sec70cuda Offline
I was just thinking I should take 3/4" of stroke out of my motor so I can go faster next year. grin
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715721
11/14/19 01:42 PM
11/14/19 01:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No sir and as we know some people can screw up anything but I've beat bigger motors a lot and power adder cars on the street easy so it boils down to the COMPLETE combo. But, top fuel 330+ mph and only 500 cubes.................What's up with that........
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715732
11/14/19 02:01 PM
11/14/19 02:01 PM
Mt Morris Michigan
Mt Morris Michigan
I understand, but in all fairness the 440 has a bigger bore allowing the 440 to breath better.
Re: Andy, your 470/270TF indy 440-3 results [Re: an8sec70cuda] #2715734
11/14/19 02:03 PM
11/14/19 02:03 PM
Mt Morris Michigan
Mt Morris Michigan
LOL!
Re: Andy, your 470/270TF indy 440-3 results [Re: Thumperdart] #2715739
11/14/19 02:15 PM
11/14/19 02:15 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, the issue with this conversation is the possible parasitic loss cant be measured , cant be seen. No way to prove it either way. I just look at it from a mechanical common sense view point. I remember when I build my motor and the pan was still off, I noticed how bad the rods were layed over when the piston was at BDC. I would sure think there would be alot of friction with the piston side loaded like that . Just think how bad that would be at 7000rpm or even 6000rpm. sure seems like that would create alot of friction dragging things down a bit. Either way, it cant be a good thing.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2715741
11/14/19 02:23 PM
11/14/19 02:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Just shooting from the hip here, but I'd imagine the power curve on the 512 you built is a bit different than the small block you were running.
I guess a dyno session could maybe shed some light on that, but anyways, maybe you need to make a few changes to the car to get it down the track a little faster...maybe take better advantage of the torque from the 512...
Gearing and/or the converter?
Re: Andy, your 470/270TF indy 440-3 results [Re: krautrock] #2715753
11/14/19 03:18 PM
11/14/19 03:18 PM
Mt Morris Michigan
Mt Morris Michigan
I agree. I wouldn't be surprised if there is 2 tenths or more left in the car. I'm working on that as well. Double adjusts for the front as a start. Next time I go to the track the car will be in race trim. I guess a 10.20 is the new goal and a tunnel ram will happen regardless of results. There is another example, my 408 with 4" stroke and 4" bore ran a best of 10.38@131 mph. This 511 with 4.25 stroke ran a best of 10.40@129.75. So more cubic inches are not always a win win and I have seen a few of Millers w8 motors put a big block to shame.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2715760
11/14/19 03:31 PM
11/14/19 03:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
It can’t?
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2715764
11/14/19 03:41 PM
11/14/19 03:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
No problem...... 426 vs 383. Same bore and the 383 has the higher rod ratio.
Or better yet..... 383 vs a 383 stroked to 442(4.25 bore x 3.90 stroke).
383 rod ratio = 1.88
442 rod ratio = 1.71
Same scenario...... 10:1, rpm heads, rpm intake, 1-7/8 headers, 509 cam, 850 carb........ which wins that battle?
Not only will the bigger motor make more power...... I’m thinking the difference in power will be at least what the difference in the cubes is.
Re: Andy, your 470/270TF indy 440-3 results [Re: Thumperdart] #2715766
11/14/19 03:45 PM
11/14/19 03:45 PM
Top Fuel motors use a smaller bore with a longer stroke than the same C.I. motor that Pro Stock use, two different motors with the same C.I. rules but not in the same world are they work
H.D. Diesel ruck motors use a lot longer stroke than bore also, correct work As well as inline 6 cyl. instead of V8 also shruggy
Apples to apples and dust to dust grin stirthepot
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2715775
11/14/19 04:14 PM
11/14/19 04:14 PM
Mt Morris Michigan
Mt Morris Michigan
I can agree with that. I would never say longer stroker motors are a bad thing. I think they all have there place and if we could remove the paracidic drag that they create as you go up in stroke, how much would there be to gain. who knows, just something to think about
Re: Andy, your 470/270TF indy 440-3 results [Re: Cab_Burge] #2715778
11/14/19 04:19 PM
11/14/19 04:19 PM
Mt Morris Michigan
Mt Morris Michigan
Sure, theres alot of true here, but top fuel motors burn crazy fuel that equivalent to liquid dynamite or worse. In my case with what I use these motors for, I think the 470 would of been the better pic . It may not be for everybody. My 511 would make a great combo for a mild roadrunner imo.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2715782
11/14/19 04:25 PM
11/14/19 04:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Think about this Mopar dave, all things the same except the stroke , the smaller 470 cid has to turn more RPM than a 512 to make the same HP, more RPM is ALSO more friction per minute
