Page 3 of 3 1 2 3
Re: Cam recommenations [Re: sixpackgut] #2738746
02/01/20 02:54 PM
02/01/20 02:54 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
After some research I ordered this spring 68277306AA they were $4,69 per spring. I am told these are the mopar performance spring they sell in the kit for the 5.7 and 6.4. I have not received them yet but when I do I will report on them. I plan to check the pressures etc. I am going to use this spring with the 6.4 MDS cam in the 5.7.
Where did you order from because summit and jegs the price is double and triple what you paid. And please report back with coil bind numbers.
For my customers running stock cams such as a 6.1 or 6.4 cam, i have been using stock ls7 springs. Problem with the ls7 springs is they are down on pressure compared to stock mopar springs. But I think even the PAC springs are down on pressure compared to stock springs.
For balls out, I only use the PSI springs. I have used the Comp conical springs in some LS applications. The Comp conical springs have incredible pressures for a single spring
Coil bind on these is 1.295 no pressure numbers yet
1.98-.04 shim -1.30 coil bind is .640 -.050, good for .590
I like it. I'll start using them
Could you check coilbind on a bunch of them? For consistency
I checked 12 springs they were all really close .005 -.010 at the most
pressures were really consistent @ 1.95 they are 115 and at 1.40 they are 365 I think for a daily driver street car with .580ish lift these things are perfect and at 4.69 each I don't think you can beat it.
Re: Cam recommenations [Re: biff426] #2738754
02/01/20 03:42 PM
02/01/20 03:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I appreciate the feedback
They sound very similar to the LS7 springs I've neen using
Re: Cam recommenations [Re: sixpackgut] #2765586
04/18/20 05:51 PM
04/18/20 05:51 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Ok so finished up the swap today a couple things I noted on the higher mileage engine. This car is an ex police package 2011 charger. I have all the maint records it was well maintained. 1st the small hole in the intake rockers on 6 of the 8 were worn shut. the valve tip was not getting oil on those and it beat the valve tip up pretty bad. I replaced the all the valves and rocker arms. The new rockers have the oil holes chamfered vs the old ones, MOPAR figured out I guess that with miles it started having oiling issues. I used the SRT MDS cam. I had pushrods out of the BGE 6.4 that I put in my 66 only had 10 miles on them so I used them. Note the BGE and Eagle head hemis have the same length pushrods I measured them. I used the springs above with new lifters. I replaced the timing chain and tensioner/guides. Man this thing sounds good !!! It feels the same until about 4K then it pulls much harder. No tune yet but there is a noticeable difference.
Re: Cam recommenations [Re: biff426] #2781329
06/04/20 10:24 AM
06/04/20 10:24 AM
IL
furious70 Offline
furious70  Offline
IL
anyone know when the revision to the rockers happened?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Cam recommenations [Re: biff426] #2859651
12/13/20 11:12 PM
12/13/20 11:12 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Finally got the car on the dyno with just the cam and springs and a cat back exhaust no tuning at all it made 373HP to the rear wheels @ 5500. Tuned on it and the peak didn't change but we picked up average 25-30HP in the 2500-4500 range. I don't think you can beat this swap for the money.
Page 3 of 3 1 2 3
