Replacement U-Joint #2715681
11/14/19 12:35 PM
11/14/19 12:35 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Hi all,
Can you help me identify this U-Joint....I do not have measurements....it accidentally got thrown away in the scrap pile. The car has an 8 3/4 rear end. I've attached a photo.
Re: Replacement U-Joint [Re: scarly10] #2715706
11/14/19 01:10 PM
11/14/19 01:10 PM
Looks like a 7260 to me but you really need to measure the outside width of the cups or the inside width of the driveshaft yoke minus the retainer width to make sure you get the right one scope
The difference between the 7260 and the 7290 is not a bunch shruggy
if this is a car that will be driven hard and has a lot of traction you might want to buy a Neapco HD off road replacement joint with no grease zerk, they won't break as easy as the one you have now twocents
Re: Replacement U-Joint [Re: Cab_Burge] #2715743
11/14/19 02:29 PM
11/14/19 02:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
7260 is 2.125 between yoke inner surfaces. Overall width about 3.250. Caps are 1.078 dia.
7290 is 2.625. Width is 3.625. Caps are 1.125.
Looks like the Spicer 5-789X is the only solid 7260 joint out there based on my brief search.
Re: Replacement U-Joint [Re: CMcAllister] #2715744
11/14/19 02:34 PM
11/14/19 02:34 PM
Minnesota
scarly10 Offline OP
scarly10  Offline OP
Minnesota
Thanks for those measurements....I did find a cap....and of course I have the yoke to measure as well.
Re: Replacement U-Joint [Re: scarly10] #2715784
11/14/19 04:30 PM
11/14/19 04:30 PM
Locomotion Offline
Locomotion  Offline
Make sure it's not a combo-joint!
