Gas
#2715629
11/14/19 07:55 AM
11/14/19 07:55 AM
Posts: 4,525 Daisyland USA
jnkgal
Daisyland USA
What is the cleanest gas to use in your daily driver?
"A goal without a plan is just a wish."
Re: Gas
[Re: jnkgal]
#2715630
11/14/19 08:49 AM
11/14/19 08:49 AM
Posts: 1,383 Az
69hemibeep
Az
As far as detergent in the gas QT in our area but if you want gas that is clean the Costco near me get 6 deliveries a day nothing settles in those tanks LOL
1969 Hemi Roadrunner 2nd owner
Re: Gas
[Re: larrymopar360]
#2715843
11/14/19 07:06 PM
11/14/19 07:06 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I worked in a gas station from 1974-1977 and we would use a long stick every morning to see how much gas was in our four 12000 and 6000 gallon underground tanks. We also put a white paste on the stick to see how much water was in each tank. If it got over 1/2 inch we would tell the delivery guys and they would at the refinery put a “dry gas” additive to absorb water. Now each tank had an outlet 6-12 inches from the bottom of the tank that would drawl gas out going to the pumps. The problem arises went gas is delivered and dropped into the tanks mixing all the dirt, water, and crud from the bottom of the tank. Are there filters at the pump? Yes there should be but I have always kind of bypassed gas stations went I see a fuel delivery truck dropping fuel.
Re: Gas
[Re: pittsburghracer]
#2715924
11/14/19 09:19 PM
11/14/19 09:19 PM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Pittsburghracer, me too! I never knew if it was the case or not, but I figured it was a logical theory that it would mix any sediment at the bottom of the tanks.
Facts are stubborn things.
Re: Gas
[Re: larrymopar360]
#2715943
11/14/19 10:12 PM
11/14/19 10:12 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I like BP and Kwik trip Up here. The hot rod always gets gas from Shell. I feel their 93 is superior to most.
1969 Dodge Dart Swinger
Re: Gas
[Re: jnkgal]
#2717910
11/20/19 07:42 PM
11/20/19 07:42 PM
jnkgal
Daisyland USA
Thanks guys for the replies. It was recommended that I use Shell gas only. I wanted to see what others thought. Has anyone used a product called Seafoam? How did it rate? I have also been told that some vehicles are sensitive to it.
Re: Gas
[Re: jnkgal]
#2717915
11/20/19 07:55 PM
11/20/19 07:55 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sea foam is fantastic. It was recommended to my on a motorhome forum for my generator that sat four years unused. Good stuff
Re: Gas
#2718518
11/23/19 12:36 AM
11/23/19 12:36 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
It will get a carb back right. It is god stuff. I also use stabil. Sea foam is fantastic. It was recommended to my on a motorhome forum for my generator that sat four years unused. Good stuff
