Small block question. Anyone use the
#2715320
11/13/19 01:10 AM
11/13/19 01:10 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Does any one use the 3.9 timing chain tensioner on their smallblock V8? I have two here. Redoing a 408 stroker with a 220ish @ 0.050 cam.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: Small block question. Anyone use the
[Re: Dave_J]
#2715346
11/13/19 08:48 AM
11/13/19 08:48 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m race only but I would rather and do spend a little extra for a quality chain and never bother with them.
[Re: pittsburghracer]
#2715364
11/13/19 11:07 AM
11/13/19 11:07 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
I ran one on my LA 360 for a number of years. No issues...
[Re: Dave_J]
#2715372
11/13/19 11:26 AM
11/13/19 11:26 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
They work great. Some will say the double roller spines will gouge the teflon slippers though, I have not had that issue. Run a stronger 'silent' chain with the smooth back and they will get your timing rock solid. Getting a quality chain may not prevent it from sagging after 10k. Look at all of them after you remove the timing cover.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: pishta]
#2715621
11/14/19 03:35 AM
11/14/19 03:35 AM
Dave_J
Auburn WA
OK, I will be prep'ing one. I drilled a 3/32" hole in the right lifter gallery core plug right behind the cam retainer plate and will drill a bigger one in the tensioner so oil will feed the chain better. Ive done this on a few smallblock engines.
These Magnum blocks main bearing feeds are already drilled out bigger than the Herb McClandless spec's of 9/32".
they are 5/16" from the right lifter gallery feed down to the main bearings. And all but one of the oil holes from the oil pump mount up to the 90 degree over to the oil filter plate are drilled at 1/2 inch, BUT the return from the filter was only 7/16" and VERRRRY rough, looks like what is left over when a drill breaks off while boring. NASTY. I drilled it out to 1/2" and it is now a clean bore. I am using the Magnum 6 hole oil filter plate but drilled the 6 holes from 1/4" out to 13/32" , Just because I can.
My 5.9 Magnumn block has a Production date stamp of 24708 and "Hecho en Mexico" . I thought that the 5.9 stopped in 2003.
[Re: Dave_J]
#2718660
11/23/19 03:07 PM
11/23/19 03:07 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I bought and ran that tensioner in my Magnum based 408. It seems to work well, but it is really just a chain guide. Once the side plates of the chain links cut through the nylon, the rollers roll down the nylon with little to no wear on the nylon block.
The best trick I've found to keep my timing chains tight is to soak them on their side in quality synthetic gear oil.
I stumbled across just how good of a break in lubricant that stuff is when I ran out of chainsaw bar & chain oil one time. I substituted Redline synthetic gear oil in my saw and the life of my chains more than quadrupled. It was nothing short of amazing.
Started soaking my timing chains in it, and it has virtually eliminated any chain stretch in half a dozen of my motors so far. The results are remarkable.I also use the highest quality timing sets available. .
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2718663
11/23/19 03:09 PM
11/23/19 03:09 PM
Posts: 6,221 nowhere
Sniper
nowhere
I bought and ran one in my Magnum based 408. It seems to work well. The best trick i've found to keep my timing chains tight is to soak them on their side in quality synthetic gear oil.
Started soaking my timing chains in it, and it has virtually eliminated any chain stretch in half a dozen of my motors so far. The results are remarkable.I also use the highest quality timing sets available. . That is probably the best advice I've seen regarding timing chain stretch
[Re: Sniper]
#2718758
11/23/19 10:42 PM
11/23/19 10:42 PM
Posts: 22,695 Bitopia
jcc
Bitopia
This makes me wonder, is a roller cam vs a FT easier on a timing chain and/or require less lubrication?
[Re: Dave_J]
#2718914
11/24/19 03:52 PM
11/24/19 03:52 PM
Dave_J
Auburn WA
Thanks for all the replies above. Wish we had a "LIKE" button on here. Since I am using a 5.9 magnum block and a roller cam that is a step above a 340 Resto cam it should not be adding a lot more force on the cam gear. With 410 ci (4.040 Bore and 4.0 Stroke) I picked a Luniti Voodoo roller 219/227 @0.050 and 0.549/0.565 @ 1.6:1 rockers. Should have a nice rumble out of the two STACK's of my LRT. The Edelbrock aluminum heads I got from Mancini are horrible right out of the box. Core shift on the exhaust ports makes it hard to gasket match but I was able to get them very close with just a little gasket sticking in the stream on 1 port on each head. Then the casting flash and boogers in the ports and the hardened valve seats have a huge step on the intakes that I had to blend down. And the oil drain back holes are small too. I am not doing a race port job on these, just a good cleaning of flash and boogers and a little blending in the pockets. The timing chain tensioner is like I said, drilled so oil pressure from the right lifter gallery can force feed oil to the chain. All the oil passages are larger than a stock LA smallblock and I am using a blueprinted Melling 572 High volume pump. After my first oil change I am adding a dual oil filter set up but one of the filters will be a restrictive flow 2 micron bypass filter that feeds back to the timing chain cover adding more "SUPER CLEAN" oil to the chain area.
[Re: Sniper]
#2719124
11/25/19 11:44 AM
11/25/19 11:44 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Started soaking my timing chains in it, and it has virtually eliminated any chain stretch in half a dozen of my motors so far. The results are remarkable.I also use the highest quality timing sets available. . That is probably the best advice I've seen regarding timing chain stretch I'll concur that a pre-soak will extend chain life. My old company used modified double roller and silent chains for conveyance sections in the larger assembly machine. We did studies on different chains, material, and process and the pre-soak was a significant increase in usable chain life. Think how long it would take oil to make it's way into those roller as that chain is spinning around after a dry start on a new build. It's not running in a bath.
[Re: gzig5]
#2719207
11/25/19 03:23 PM
11/25/19 03:23 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've just installed the tensioner on my new 410 sb, using a ProGear Hughes timing chain setup (that shouldn't make any difference). Looking at the front of the engine, I observed the lower left corner of the tensioner was making contact with the installed SLINGER PLATE! So, I carefully masked and ground away some extra clearance at the area ... using a Dremel tool and small grinder.. ground away about 1/8" from lower corner of the tensioner so that it clears the SLINGER... if it wasn't ground for the clearance, then the SLINGER would've been at a slight angle when the balancer would press against it... not good.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2719230
11/25/19 04:48 PM
11/25/19 04:48 PM
Dave_J
Auburn WA
This is all good information. Thanks y'all.
I use to take half a tube of 'White Lithium' assembly lube and mixed it 50/50 with 10W30 and painted parts and soaked the lifters and chain in it too. There a lot more assembly lubes out there today.
