Re: Street strip valve spring pressure?
[Re: cudadoug]
#2714724
11/11/19 09:54 AM
11/11/19 09:54 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Going out on a limb, this is a solid roller. Seems a little backwards not starting with the cam lobe profiles and rpm range to pick your springs.
If you are using spring pressure to back into your cam choice, a lot of folks seem to use that type of spring on street cars. I think the comp 943 spring is commonly used.
[Re: cudadoug]
#2714800
11/11/19 01:27 PM
11/11/19 01:27 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
About where I'm at w/a .680.660 Isky solid roller in the mid 9's for several years w/one lifter rebuild and spring swap......
[Re: cudadoug]
#2714837
11/11/19 03:15 PM
11/11/19 03:15 PM
Posts: 4,206 New York
polyspheric
New York
Regardless of spring pressure or RPM, high lift beats up the stem-guide contact with thrust at a high angle. There is no way around this (except relocating the entire rocker shaft assembly, and even that does very little), since it's a function of the ratio of the rocker arm's long (valve-side) lever length vs. lift: low numbers are bad.
Boffin Emeritus
