'70 Charger Headlight Door Rivets #271451
03/30/09 12:14 PM
03/30/09 12:14 PM
Detroit
HogRidinFool Offline OP
Detroit
The rivets attaching the plastic headlight door cover to the door frame are loose and the door rattles (especially when idling). Does anybody offer new rivets or any "backyard" suggestions about tightening them up? Thanks
Re: '70 Charger Headlight Door Rivets [Re: HogRidinFool] #271452
05/06/09 09:19 AM
05/06/09 09:19 AM
Detroit
Detroit
BTT....Anybody?
Re: '70 Charger Headlight Door Rivets [Re: HogRidinFool] #271453
05/06/09 09:24 AM
05/06/09 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd just drill them out and use a small bolt/nut combo.
Re: '70 Charger Headlight Door Rivets [Re: Mr.Yuck] #271454
05/06/09 11:15 AM
05/06/09 11:15 AM
Detroit
Detroit
I wish I could. The exposed rivet face is actually part of the headlight door face decor. Plus its flat black. Using a nut & bolt would offer a "not so original" look. Thanks though!
2010 Mopar 10 #000-500
Re: '70 Charger Headlight Door Rivets [Re: HogRidinFool] #271455
05/06/09 11:20 AM
05/06/09 11:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Oh I though you were talking about the ones on the side. good luck maybe you could inject some glue and let them set-up for a day or two. Or maybe if they are really loose try and wedge some thin pieces of plastic between the rivet head and the back of the door. Kind of like a shim?
