J.W. 727 sfi Bellhousing #2714453
11/10/19 09:43 AM
11/10/19 09:43 AM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Anyone here use the J.W. 727 SFI Ultra-Bell housing?
Wondering is it is worth the effort and $$
Re: J.W. 727 sfi Bellhousing [Re: Chip] #2714458
11/10/19 09:56 AM
11/10/19 09:56 AM
NYC
Dartari Offline
Dartari  Offline
NYC
IMO yes
Re: J.W. 727 sfi Bellhousing [Re: Dartari] #2714490
11/10/19 12:03 PM
11/10/19 12:03 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I'm still having issues with starter engagement.
Starter has to spin once before it engages the 2nd time.
Going to try and shim it out some.
The nose of the starter was tight going in to the Jw bell starter hole.
Re: J.W. 727 sfi Bellhousing [Re: Chip] #2714498
11/10/19 12:20 PM
11/10/19 12:20 PM
moparx Offline
moparx  Offline
big block or small block ?
i am trying to find an affordable [to me] used big block unit.
beer
Re: J.W. 727 sfi Bellhousing [Re: moparx] #2714528
11/10/19 01:22 PM
11/10/19 01:22 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
beer
I am looking for the same, with the US/Canuck exchange rate, its a pretty hefty price. If I can't find one, I'm working on a jig to aid in welding on a b/rb bellhousing onto a 46rh, I don't require the SFI rating for my project.
Re: J.W. 727 sfi Bellhousing [Re: Uberpube] #2714581
11/10/19 05:12 PM
11/10/19 05:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It has been done.
Re: J.W. 727 sfi Bellhousing [Re: John_Kunkel] #2714784
11/11/19 12:59 PM
11/11/19 12:59 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
It has been done.
haha, Thats great, the splice line is exactly where I marked it to be on my trans....I was wondering about the weldability of the housing, sometimes cast aluminum doesn't well to well. Any info on how that one worked out?
Re: J.W. 727 sfi Bellhousing [Re: Chip] #2714792
11/11/19 01:17 PM
11/11/19 01:17 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
When we bought the Daytona a trans shield wouldn't fit the tunnel without some major work. We installed the JW bell and it worked perfect! We have since changed to a Glide so I have the bell for sale (haven't advertised it yet). I think there is one more season on the cert (I will have to check)
Re: J.W. 727 sfi Bellhousing [Re: Uberpube] #2714799
11/11/19 01:26 PM
11/11/19 01:26 PM
A727Tflite Offline
A727Tflite  Offline
It has been done.
There was a guy that started doing this in the northwest back in the early 90’s, somewhere around Seattle.
Re: J.W. 727 sfi Bellhousing [Re: A727Tflite] #2714835
11/11/19 03:13 PM
11/11/19 03:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Zero issues with the stock 1965 727 case. 600 passes. Car runs 9.0-9.1@3350lbs
Doug
Re: J.W. 727 sfi Bellhousing [Re: Chip] #2714856
11/11/19 04:20 PM
11/11/19 04:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I put one on my A518, has about 8K miles on it.
