Re: Question: "low voltage at idle" deal
[Re: Mattax]
#2714858
11/11/19 03:27 PM
11/11/19 03:27 PM
Posts: 7,386 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Burdar I put in new flasher dealies for both turn signals and hazard. Did you install the original kind or the full electronic ones? When I got my Challenger on the road, the turn signals only worked half the time. I replace the flashers with new "original" style units and got the turn signals to work all the time. However, when coming to a stop, they would flash really slow. The full electronic flashers fixed that issue and they now flash at a consistent rate. You may have other issues but the electronic flashers are a good upgrade IMO. Good luck!
[Re: hemienvy]
#2715014
11/12/19 03:38 AM
11/12/19 03:38 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
And a cheap 12 volt test light is your friend when working on these old Mopars. A glass fuse may look good but I gave a few in my tool box that look solid but one end under the cap was disconnected. A test light will show if the fuse is good. If it lights on one side but not the other, toss it. Stanwood is a 82 mile ride. Thats only 3 gallons of gas ROUND trip on my scooter. I will be going thru my wiring on my 78 LRT soon. The bulkhead connector is all green. I'll also be doing the Alternator feed straight to the battery and back feeding the AMP meter.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2715037
11/12/19 08:55 AM
11/12/19 08:55 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
the Alternator feed straight to the battery and back feeding the AMP meter. The alternator's 2nd job should be to recharge the battery. The alternator should connect as direct as possible with the power distribution point(s). Do not back feed an ammeter: (a) it then becomes meaningless (b) the circuit can become overloaded. The ammeter is for the battery only. It should not also carry the power to be distributed to the rest of the equipment.
[Re: moparx]
#2715466
11/13/19 03:37 PM
11/13/19 03:37 PM
Mattax
Phila. Pa.
Whether it would be worthwhile depends on the person! Witness how many owners don't know what the ammeter shows. If you want to see whether the battery is getting charged, how much it is being charged and for how long; and whether it is discharging, how much it is discharging and for how long, then this type of ammeter is useful. Not every car company offered ammeters on their baseline cars and trucks. Some used 'idiot lights' which arguably may grab a driver's attention when something is wrong. In contrast, a gage pointing to any particular point, or even an extreme has to be interpreted as to whether it is normal, abnormal or even dangerous conditions. There's at least one post on the IFSJA forum where TWICE the owner left something on, needed a jump start. The second time he attempted to drive home even while ammeter (which goes to 60 amps) was pegged to charge and he could tell the wires was sizzling. He got lucky and the fusible link finally melted before something flammable lit up. Now here's the thing. An ammeter alone doesn't tell the whole story. If we see what appears to be excessive charging, we still need a voltmeter to help us narrow down the cause. If the voltage across the battery was in normal rangewhile the ammeter is showing this, its probably due to the battery excessively low condition. In this scenario, we'd ant to try to get the battery on a charger, and if not available, keep the rpms as low as possible so the battery doesnt get hot. (or the wires!) On the other hand, if the voltage across the battery is at say 16 Volts, then excessive current to the battery would be due to the high voltage driving it. Something is wrong on the regulation side. Either the regulator is getting bad info or its not working properly. So a dashboard voltmeter shows potential being maintained by the battery or the alternator. and a dashboard ammeter shows whether battery charging or discharging is occuring. Hope that makes sense.
[Re: Mattax]
#2715710
11/14/19 12:15 PM
11/14/19 12:15 PM
Posts: 20,536 north of coder
moparx
yes it does. however, using a large amp alternator, the biggest [highest ?] rated amp gauge i have seen has been only 60 amps. how would this figure into the equation ?
[Re: moparx]
#2715728
11/14/19 12:55 PM
11/14/19 12:55 PM
Dave_J
Auburn WA
I had a major issue when I was running a 120 Amp cop car alternator. It would PEG the dash Amp meter after every start for 1-2 minuets or so. So IF you run not much over the factory old school 45 Amp alternator you are fine but.... What is really needed is a "look-a-like" Mili-Amp meter that has a shunt in the back. When you run say a 90/120 amp alternator only a small portion of the amperage goes thru the miliamp meter but the major amps bypass it thru the shunt.
If you are still wanting to run the factory 60 Amp MAX amp meter with a HUGE amp alternator, you could somehow figure out a by-pass shunt wire to strap across the amp meter so it will still see a discharge/charge. Run a 6 gauge red wire from the alternator to the shunted amp meter with maybe the shunt wire being a 16 gauge and then a 6 gauge black wire to the battery. This will not be 100% accurate but it should work.
Or just bypass the amp meter like what I have done in the past. None of my daily drivers will ever go go a 'POINTS' car show so I run a 2 gauge pod under the dash with a Oil pressure and a volt meter.
[Re: moparx]
#2716027
11/15/19 08:43 AM
11/15/19 08:43 AM
Mattax
Phila. Pa.
the biggest [highest ?] rated amp gauge i have seen has been only 60 amps. Probably because if there's more than 40 amps going to the battery there's a problem - at least in a normal setup. however, using a large amp alternator, how would this figure into the equation ? It depends on the alternator; But if its capable of producing more power, then its more likely to provide a high charging current to a low battery. Some examples of alternator curves in these two posts https://board.moparts.org/ubbthread...ories-amp-gauge-re-wire.html#Post2714603You've probably observed that batteries draws more current when more heavily discharged. And the closer it gets to full charge, the less current it draws. This is true as long as the power is available, and the voltage its available at is unchanged. About 1/2 way down this thread I post a sequence of charging photos with timestamps. https://www.forabodiesonly.com/mopar/threads/charging-battery-with-alternator-warning.424783/Notice in the beginning, I manually reduce the power available, dropping the voltage from the charger.
[Re: Mattax]
#2716330
11/16/19 09:57 AM
11/16/19 09:57 AM
moparx
i understand the amperage needed in a totally [or almost totally] discharged battery will be very high, [your graphs are good by the way] and as you approach 40 amps charging, you are closing in on dangerous territory as far as charging goes, but i think my main question is, can you safely use a 60amp gauge on a say, 100amp alternator system ? this, of course, is using the bypass diagram you posted above, and your wiring system is in good working order. for the last many, many years, all my wiring [original harness and from scratch] has been centered on using a volt gauge only, [in creating a new harness] and disconnecting the original amp gauge, or converting it to a volt gauge in an original or reproduction harness. now, high amperage alternators are a common addition, and for one of my own projects, i would like to run an amp gauge as well as a volt gauge, but was somewhat concerned about the available amp gauges only coming in at 60 amps. [if a guy has a draw or input of that amount, you have problems ! ] comments ?
