Re: 99 Ram 2500 V10 with a tick tick tick noise.
[Re: moparjo68]
#2713890
11/08/19 08:42 AM
11/08/19 08:42 AM
Posts: 1,030 ohio
67mprfan
ohio
Possible crack in the exhaust manifold Or warped on the face of the manifold
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: moparjo68]
#2713902
11/08/19 09:43 AM
11/08/19 09:43 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
99 Ram 2500 with 153,000 and a V10 that all of a sudden starting a tick tick tick noise while running/idling. The noise came on instantly. I immediately did a compression test. High number was 160. Low number was 135. I saw a youtube video that someone had the same ticking noise as my truck engine. He removed the valve cover and a rocker arm bolt had sheared off causing the tick noise.
My question is: Without removing the valve covers to look for broken/loose rocker arm bolts, would the compression test readings tell me what I need to know. Meaning: wouldn't I get a real low reading if the intake valve can't open and no air is able to enter the cylinder on the piston's downward stroke? 160 to 135 is too much of a difference between cylinders if you ask me. Yes the compression will be lower if the intake valve can't open at all, might be higher if the exhaust can't open but even if they partially open then compression will be affected. I think you need to pull the rocker covers.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: gtx6970]
#2714027
11/08/19 04:46 PM
11/08/19 04:46 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
He removed the valve cover and a rocker arm bolt had sheared off The same exact thing happened to mine with 48K miles on it. Pull a valve cover & take a look.
[Re: moparjo68]
#2715795
11/14/19 04:51 PM
11/14/19 04:51 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
OK. Here's an update. I just removed the valve cover from driver's side. The valve train looks good. No sheared off bolts. Everything is snug. No loose parts. No broken valve springs. But here is what really concerned me. I noticed small traces of anti freeze pooling in the head. What does that mean? That means really bad things. Most likely culprit is a crack in a cylinder head.That's the only way i can think of coolant getting under the valve cover other than being blown in through the breather. That, in itself, would also be a very bad thing.
[Re: feets]
#2715963
11/14/19 11:06 PM
11/14/19 11:06 PM
Posts: 486 Sonoran desert, Arizona, USA
moparjo68
I was afraid when I saw the anti freeze under the valve cover that the motor was toast. I just stopped working on it and figured its time to hunt another v10.
[Re: moparjo68]
#2716182
11/15/19 06:49 PM
11/15/19 06:49 PM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I was afraid when I saw the anti freeze under the valve cover that the motor was toast. I just stopped working on it and figured its time to hunt another v10. First thing I would do is crack the drain plug in the oil pan and see how much green comes out first. Then I'd pressure test the cooling system before I went into panic mode. Kevin
[Re: Twostick]
#2716205
11/15/19 07:43 PM
11/15/19 07:43 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
I was afraid when I saw the anti freeze under the valve cover that the motor was toast. I just stopped working on it and figured its time to hunt another v10. First thing I would do is crack the drain plug in the oil pan and see how much green comes out first. Then I'd pressure test the cooling system before I went into panic mode. Kevin This ^
