heads questions #2713229
11/06/19 02:47 AM
11/06/19 02:47 AM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
Will B/RB Wedge heads bolt on to a 426 Hemi block?
Re: heads questions [Re: mopacltd] #2713235
11/06/19 07:54 AM
11/06/19 07:54 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
No.
Top row of head bolts are not the same pattern.
Some wedge heads may have coolant holes where the hemi block exhaust pushrod relief is.
Also would need to block the corner oil drains in the block.
Re: heads questions [Re: TRENDZ] #2713276
11/06/19 10:39 AM
11/06/19 10:39 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
No. Except the most powerful of the aftermarket heads which are sometimes made to use a hemi block so they can put the ports where they want and it gives what will be a powerful engine a better bottom end block.
2011 Drag Pak Challenger
Re: heads questions [Re: mopacltd] #2713412
11/06/19 04:03 PM
11/06/19 04:03 PM
AndyF Online content
AndyF  Online Content
Some of the bolts will go in but the engine won't run without extensive modifications.
Re: heads questions [Re: AndyF] #2713548
11/06/19 10:57 PM
11/06/19 10:57 PM
gregsdart Online content
gregsdart  Online Content
Since my megablock was clearanced (looks like) for hemi pushrods, maybe the only difference in those bocks may be that upper row of head bolts? I have often wondered if they could be plugged and redrilled and tapped to run hemi heads. The metal is there for the hemi pattern.
Re: heads questions [Re: gregsdart] #2713557
11/07/19 12:16 AM
11/07/19 12:16 AM
Nebraska
U
unclbuck Offline
unclbuck  Offline
U
Nebraska
It can be done up
Re: heads questions [Re: unclbuck] #2713558
11/07/19 12:17 AM
11/07/19 12:17 AM
Nebraska
U
unclbuck Offline
unclbuck  Offline
U
Nebraska
In regards to the making a mega wedge block into a hemi block
