Re: Big block 727 question
[Re: 451Mopar]
#2712905
11/05/19 08:36 AM
11/05/19 08:36 AM
Posts: 4,276 Florida
blewbyu
I don't know by part number, but the HP trans usually has the 4-pinion front planetary gear and 4-clutch front drum, and some non-HP just have 3-Pinion, 3-Clutch Drum. Not sure if the governor is a different shift point. The parts interchange, so no problem upgrading a low performance to HP specs. If in the budget, Bolt-in super sprag and Billet front drum (5-clutch) are great upgrades for safety and performance. I believe only Hemi trans had the 4 gear planetary?
[Re: 6PAX]
#2713034
11/05/19 03:10 PM
11/05/19 03:10 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The earlier 440 HP had 4-pinion planetaries front and rear, 440 standard performance had them in the front only. Any 440-4 will have 4-disc front and rear clutches. Governor is different in the HP.
In '72 most 440's had the 4-pinion in the front only.
