Re: Voltage limiter does what? [Re: jeff968] #2712290
11/03/19 12:10 AM
11/03/19 12:10 AM
pull the yellow wire off of the starter relay to disable the starter then have a helper hold the key to "start" & you with your meter check for continuity from the ign key brown wire ign2 terminal downstream thru every terminal/connection out to the coil positive primary terminal/power in terminal on the ECU pentastar connector. ignwise if those 2 are being fed while cranking it will start
Re: Voltage limiter does what? [Re: RapidRobert] #2712452
11/03/19 03:15 PM
11/03/19 03:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I had a customers car several years ago that was doing the same thing. His problem turned out to be the 12V power for the ECU was tied to the wrong side of the ballast which in turn limited the voltage to about 8V or so. Might want to double check that wiring beer
Re: Voltage limiter does what? [Re: TJP] #2712547
11/03/19 09:42 PM
11/03/19 09:42 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Straight forward to troubleshoot... Connect a jumper lead bypassing the ballast resistor, this will give max voltage/current to the coil...
Run it for a short time and post back the results..
Better or worse?? Any changes??
Also be sure the reluctor gap is within spec..
Just my $0.02... wink
Re: Voltage limiter does what? [Re: Sinitro] #2712630
11/04/19 11:03 AM
11/04/19 11:03 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Got it figured out!
Was driving Friday when the problem occurred. I hooked up my spark detector to a spark plug wire and confirmed no spark when cranking. Buddy checked ECM with test light when cranking, POWER! Then moved to coil while cranking, POWER! So that left only one possible culprit, the distributor. So, I replaced that with a used one on Saturday and I think that did it. The car has been 100% since.
Thanks for the suggestions but I think I got it.
1970 Dodge Challenger T/A
Re: Voltage limiter does what? [Re: jeff968] #2712665
11/04/19 12:56 PM
11/04/19 12:56 PM
You sound pumped!
Re: Voltage limiter does what? [Re: RapidRobert] #2712705
11/04/19 02:45 PM
11/04/19 02:45 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Originally Posted by RapidRobert
You sound pumped!
You have no idea! boogie
Re: Voltage limiter does what? [Re: jeff968] #2712707
11/04/19 02:55 PM
11/04/19 02:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You were bound to find it sooner or later. You've replaced everything else. laugh2 thumbs
Re: Voltage limiter does what? [Re: burdar] #2712767
11/04/19 05:59 PM
11/04/19 05:59 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
So true, I just never suspected my newer Mopar performance distributor.
Re: Voltage limiter does what? [Re: jeff968] #2713763
11/07/19 04:44 PM
11/07/19 04:44 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Thanks for reporting back and glad to hear the you got it figured out. Nice, logical bit of trouble shooting at the end to finally identify the problem. up
