Alignment shop recomendation #2712535
11/03/19 08:59 PM
11/03/19 08:59 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Hello
Can anyone recommend an alignment shop in Tucson? Car is a 68 Charger with QA1 UPA. Looking for a shop that has experience with older cars. Thanks
Frank
Re: Alignment shop recomendation [Re: frank] #2712637
11/04/19 11:36 AM
11/04/19 11:36 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Find out where the local racers take their cars. These guys will be the most capable and willing to take on custom specs. Or, try looking up race car fab shops and see who they recommend.
Are you using radials? If so, I'd recommend a more aggressive setting with more negative camber and more positive caster. If bias ply, use the stock specs.
