foam gaskets between brake back plate and front spindles #2712181
11/02/19 06:35 PM
11/02/19 06:35 PM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all, just wondering if anybody makes those little foam gasket that go between the brake back plates and front spindles ?
Later, BuZZ
Re: foam gaskets between brake back plate and front spindles [Re: buzz440] #2712187
11/02/19 07:01 PM
11/02/19 07:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: foam gaskets between brake back plate and front spindles [Re: buzz440] #2712197
11/02/19 07:25 PM
11/02/19 07:25 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I make mine from some white packing sheet foam and a utility knife. Lay backing plate on foam, trace inner hole and add about 3/4" for outer circumference and cut. Nice gasket. Looks just like factory. (you can't see it)
Re: foam gaskets between brake back plate and front spindles [Re: boydsdodge] #2712229
11/02/19 09:17 PM
11/02/19 09:17 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have made mine a few times also. I had a hard time finding the white foam of the right consistency though. I would take a metal can with the correct size needed and smack the can with a block of wood while the foam was on a smooth concrete floor. The can would cut into the foam. Perfect circle.
Re: foam gaskets between brake back plate and front spindles [Re: mopars4ever] #2712497
11/03/19 05:52 PM
11/03/19 05:52 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Same here also...................
