Page 3 of 3 1 2 3
Re: Anyone see a problem with my rollbars ??? [Re: bonefish] #558716
12/21/09 06:15 PM
12/21/09 06:15 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
Holy smokes ,i didnt mean to turn this into a debate on welding technics.This freind that welded the tubes for me for FREE is not a certified welder ,but he does make them look better than i do with a mig.I can weld circles around him and most others with a stick welder ,but not a mig.As far is his welds go ,he welded a tube axle in a gasser i used to own .I ran over 110 in that car many times and it never broke the pads loose from the axle where he welded it.In a deal like that if the weld gave loose on the axle ,you may as well kiss it goodby.If i trusted him on that ,i figure he was good enough to weld a roll bar that will probably never get used anyway (i hope).Thanks again for all the feedback and i think im good to go with what we did as is ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Anyone see a problem with my rollbars ??? #558717
12/21/09 06:22 PM
12/21/09 06:22 PM
Sherman Texas
Sherman Texas
Aside from all the weld critiques which was very educational, I have a question and am surprised nobody else picked up on it. Are you planning on using a 5 point harness? There could be a major problem. I don't know how tall you are, but if you are planning on routing the shoulder belts through the seat, you will fail. The cross bar cannot be higher than shoulder height and no more than 4 inches below shoulder level. If you are planning on routing the shoulder belts over and around and the racing seat headrest, than you could be ok if it is within the 0 to -4" or 90 degree driver to shoulder belts angle. If not, that bar will not pass. You should really check these measurements while seated to make sure you will be safe. Even if only going to run "low 11's"
On another note, it drives me a little crazy when folks say they are only going to go "this" fast. Guess what, someone that is faster than you will be chasing you one day and all hell may break loose and you are in the cross hairs of the faster car. God forbid you are ever in this situation. Do you want to plan for your car only going so fast, or plan on what could happen and know that you followed the guidelines to make sure you kept yourself safe? If what I said about your belt mounting measurements/angles are off, if your car were to fold on impact, your spine would be compressed/crushed from the shoulder belts down. Other than looking out for you, the bar looks like a job well done. Thanks for asking everyones opinion. If you want me to copy the rollbar and seatbelt sections of the rulebook for you, just drop me a PM
-Jason
Im 6'2 and the rules state that the shoulder straps must limt upward and forward motion of the driver.If the seat bar is below my shoulders by a few inches when im seated ,and the seat straps are wrapped around the seat bar ,why wouldnt it limit upward and forward motion ? Yes ,im planning on a 5 point harness as the rules state with a roll bar ...
Re: Anyone see a problem with my rollbars ??? [Re: wildcargo] #558718
12/21/09 06:35 PM
12/21/09 06:35 PM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
Maybe some certified welders will jump in here also.
Here a certified welder from the Netherlands, vertial up is better than start-stop-start-stop downwards.
The main reason is NOT that downwards welding is not good (lot of wires/sticks these days that only alow you to weld downwards) but every time you start welding you got the most chance at binding folds (sp?)
Re: Anyone see a problem with my rollbars ??? [Re: 383duster] #558719
12/21/09 07:45 PM
12/21/09 07:45 PM
okla.
sam64 Offline
sam64  Offline
okla.
and they all pull their cars to the track wearing what the factory put in their tow vehicle, never checking to see if the bolts were ever tightened.put your car together and go racing,its a fact when its your time to go,it doesn't matter what you've done.
Re: Anyone see a problem with my rollbars ??? #558720
12/21/09 09:17 PM
12/21/09 09:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
-Jason
Good eye on the shoulder harness mounting angle , nobody else including me caught it.
If that is your chosen seat, then you have safety problem. I don't know nor care if an inspector catches it or not. If the seat can be raised or another bar added, problem solved. The belted driver is mainly restrained from upward movement by the lap/crotch belt, the shoulder harness is primarily to restrain forward motion of the main mass of the body. The pictured y? belt single shoulder harness ( also nhra declined) seat opening would distort the shoulder harness and or seat, and is way too far down. To low is another topic. Far all this trouble, you do not want your head or body to be hitting this finely welded roll bar in a heavy on track incident, and of course their is resale value to consider.
Re: Anyone see a problem with my rollbars ??? [Re: jcc] #558721
12/21/09 10:36 PM
12/21/09 10:36 PM
Sherman Texas
Sherman Texas
-Jason
Thanks ,but what your eagle eye missed is that im 6'2 /220 lbs and with my helmet on in this car with the seat mounted where i put it(which is basically on the floor),im maybe 3 inches from the roof.I dont plan on using the should strap hole in the seat .I am just going to run the shoulder strap around the seat bar as required and then over the seat ,thus correcting the problem.I look like a giant sitting in the seat of this Dart.The very top edge of that seat is even with my shirt collar .I had my freind take the measurements for the seat bar ,door bars ,main hoop ,etc ,with me sitting normally in the seat with my helment on as the instructions said to.I didnt rely on a hole in the seat to position anything. Your right on the resale thing ,a short man wont fit the car with the seat where i mounted it.I dont think its required to run the seat belt shoulder straps through the seat back ,if it was how do people with factory bench seats or factory buckets and a 5 point seat belt get through tech ? BTW, i dont plan on using that lap belt as its not legal to use a lap belt with a rollbar in any class ,at any speed ...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558722
12/21/09 10:49 PM
12/21/09 10:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not about the bar but you might look at your shifter location again. Pretend your strapped in and see if you can reach up and get it out of park. I had this problem with my last shifter setup. I had to strrreeettttcchhhh when strapped in to take the car out of park, seemed perfectly fine until I put a harness in it.
68 Barracuda Formula S 340
Re: Anyone see a problem with my rollbars ??? [Re: Bad340fish] #558723
12/21/09 10:55 PM
12/21/09 10:55 PM
Sherman Texas
Sherman Texas
Thanks ,and your right,It may very well be a problem with me strapped in the seat to reach the shifter in park.I will check that out.It shouldnt be too hard to move it back a little if it is...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558724
12/22/09 09:06 AM
12/22/09 09:06 AM
west palm beach, florida
modelmakerinc Offline
I often wondered why so many people put the switches next to the shifter or on the halo bar in a race car until I strapped myself in and couldnt reach the dash. There are alot of little things you learn as you go.
Not that my opinion holds any authority but I think your roll bar will be fine.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Anyone see a problem with my rollbars ??? [Re: modelmakerinc] #558725
12/22/09 09:21 AM
12/22/09 09:21 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
samr thing happend to me,got the whole car wired ,all switches on the dash and the shifter mounted,i really took my time and did a good job.then got straped in and couldnt reach the switches or get it out of park(it was my first race car)BUMMER!!!!
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558726
12/22/09 09:24 AM
12/22/09 09:24 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
-Jason
The I guess I incorectly assumed you were the seat pictured as designed, taking the shoulder harness around the outside of a seat is certaintly doable, but may not be ideal, or useful for certain "hans" type neck braces, ie too wide. It seems you addressed the shoulder harness angle/height issues. The "lap" belt I referred to was the lap belt in a 5/6/7 way belt system. And remember, the belts can only hold you as tight as the seat itself is mounted. +
Re: Anyone see a problem with my rollbars ??? [Re: bonefish] #558727
12/22/09 11:15 AM
12/22/09 11:15 AM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
What about the brackets holding the shifter up/ looks like one hard shift and thet would fold like a house of cards.
Re: Anyone see a problem with my rollbars ??? [Re: KMPX2] #558728
12/22/09 06:01 PM
12/22/09 06:01 PM
Sherman Texas
Sherman Texas
Correct you are.When the previuos owner mounted that shifter ,it had a bench seat in the car.On the last run i made in October ,i bent the "legs" of that shifter when i shifted it into high gear ,and it turned sideways.I am kinda ruff when it comes to shifting on a dragstrip (as a former 4 spd powershifter).I will be addressing that when i move the shifter back a bit.You certainly have a fine eye my freind ...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558729
01/16/10 08:11 PM
01/16/10 08:11 PM
Sherman Texas
Sherman Texas
Well i finally got around to making the seat support ,attached the 5 point and mounting tabs ,and even threw sum paint on the bars .It came out pretty well .I made the seat support out of a leaf spring plare that i cut in half and welded to sum heavy wall tubing...
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558730
01/16/10 08:12 PM
01/16/10 08:12 PM
Sherman Texas
Sherman Texas
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #558731
01/16/10 08:13 PM
01/16/10 08:13 PM
Sherman Texas
Sherman Texas
Re: Anyone see a problem with my rollbars ??? [Re: The Shocker] #2711674
10/31/19 04:56 PM
10/31/19 04:56 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
include welding handbooks, calculators, video and article libraries, safety guides, training materials and more.
Here's the article, if you're interested: https://www.ratemywelder.com/a-comprehensive-guide-to-welding-resources/
Re: Anyone see a problem with my rollbars ??? [Re: moparts] #2711685
10/31/19 06:12 PM
10/31/19 06:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Trick or treat resurrecting a 9yr old post?
Re: Anyone see a problem with my rollbars ??? [Re: go green] #2711749
10/31/19 09:53 PM
10/31/19 09:53 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by go green
If the seat does not touch the main hoop I will usually weld on a upper seat mount bracket . This makes the seat more solid and helps the driver feel whats happening with the car. IMO.
That roll bar will pass . <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" />
That it required!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 3 of 3 1 2 3
