Re: Turbo 400 full race 2.48 gear set
[Re: Sammy]
#2711350
10/30/19 06:25 PM
10/30/19 06:25 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Small block 1096 hp with Turbo 400 Rossler transmission. Want to swap out the 2.10 and go to a 2.48 race 1st gear Where are you buying them from that will hold up to 1100hp? Not sure if Rosslers parts are any better in quality than the other racing brands out there. Looking for suggestions. If you are on Facebook you will get better answers on this from some of the heads up groups.
[Re: pittsburghracer]
#2711378
10/30/19 07:20 PM
10/30/19 07:20 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Small block 1096 hp with Turbo 400 Rossler transmission. Want to swap out the 2.10 and go to a 2.48 race 1st gear Where are you buying them from that will hold up to 1100hp? Not sure if Rosslers parts are any better in quality than the other racing brands out there. Looking for suggestions. If you are on Facebook you will get better answers on this from some of the heads up groups. Thanks but I dont do Facebook or Instagram. Was hoping to get some help from the Turbo 400 users on here.
[Re: Sammy]
#2711926
11/01/19 04:25 PM
11/01/19 04:25 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
Coan cant help me. No other choice but to send it back to Rossler which I did not want to do. Rossler does not sell parts. Have you checked with Abruzzi? Marco should be able to fix you up. Maybe 15 minutes from Rossler. http://www.abruzziracing.com
[Re: sam64]
#2711967
11/01/19 08:00 PM
11/01/19 08:00 PM
Sammy
Wind Gap,Pa.
I can't comment on power potential but I have been looking to go to a powerglide and the over 1000 hp guys seem to be going 1.58-1,69 planetaries. I have no where near that but that seems to be the norm. And they are making 2 speed 400s ! Maybe with power adders but I'm sure a 3250 lb. Car with those planetary would be a real turd. Coan thinks I should try the 2.10 planetary. There thought was the I wont knock the tires off.
[Re: sam64]
#2712009
11/02/19 02:26 AM
11/02/19 02:26 AM
Posts: 43,099 Bend,OR USA
Cab_Burge
I guess it depends on the total package. I am going from a 2.45 first in a 3 speed to a 1.98 in a 2 speed. just a low buck bracket racer here. Isn't the 1.98 ratio one of the weakest gear sets made for a Powerglide? I was told that years ago by old SS Chevy racer
[Re: Cab_Burge]
#2712156
11/02/19 05:29 PM
11/02/19 05:29 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I guess it depends on the total package. I am going from a 2.45 first in a 3 speed to a 1.98 in a 2 speed. just a low buck bracket racer here. Isn't the 1.98 ratio one of the weakest gear sets made for a Powerglide? I was told that years ago by old SS Chevy racer Cab years ago the old gear sets were built using the smaller 6 cylinder 1.82 housings and I broke two different sets. The now offered straight cut gear sets are built using the heavier duty 1.76 housings and are much stronger. My 1.98 in my black duster has 3 years of 1.25-1.28 sixty foot times on them. I also have a 1.80 gear set going in my other ATI case, and a 1.69 ATI in my heads up car
