1st trip to the track this Saturday...what will it run? #2710887
10/29/19 10:32 AM
10/29/19 10:32 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
It took a couple years but this was built for my Dad as a driver with a little attitude...
72 Duster Body...frame tied with US Car Tool rails...
It's pretty complete so curb weight should be close to what stock was...No cage and no Fiberglass
3500 convertor...4.11 gears...275/60 M/T ET Streets on the rear...
M1 intake with a 750 Holley...
MSD ignition...coil...distibutor with timing at 36 degrees
Doug's 453 headers...
RVMB 727 transmission...
Engine is a 73 340 block bored .030
Decked .018 for 0 deck
ARP main studs
Mopar cast 4” crank
CAT H-beam Rods
Diamond dished pistons
Promaxx Stage 3 heads
Sorry...I don't know any cam specs...
It ran 11.20s @ 119 in the previous owners 70 Dart with w-2 heads...3350# with a 4000 converter and 4.10s with the headers open...
It's going down as-driven with closed exhaust to the back bumper...
Maybe an 11.40???
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2710894
10/29/19 10:45 AM
10/29/19 10:45 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
what do you mean by Promaxx stage 3 heads? are they their CNC ported heads or something else?
Re: 1st trip to the track this Saturday...what will it run? [Re: krautrock] #2710898
10/29/19 10:59 AM
10/29/19 10:59 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
12'0 with your dad driving ... hope he enjoys every minute of it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 1st trip to the track this Saturday...what will it run? [Re: 67mprfan] #2710899
10/29/19 11:06 AM
10/29/19 11:06 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Yes they are CNC ported...
67...I hope he has fun with it...
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2710917
10/29/19 12:09 PM
10/29/19 12:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Be safe, have fun, get some pictures of the car and Dads smile to post up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2710946
10/29/19 02:50 PM
10/29/19 02:50 PM
Track conditions and weather will determine how fast it goes, good luck, have fun thumbs
Re: 1st trip to the track this Saturday...what will it run? [Re: Cab_Burge] #2711052
10/29/19 10:40 PM
10/29/19 10:40 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
12.20 off the trailer if it hooks, 11.50s in the fall if the converter works?
Re: 1st trip to the track this Saturday...what will it run? [Re: Jeremiah] #2711106
10/30/19 07:40 AM
10/30/19 07:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are they iron heads ? Whats the comp ratio also ? Ron
Re: 1st trip to the track this Saturday...what will it run? [Re: 383man] #2711126
10/30/19 08:52 AM
10/30/19 08:52 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Aluminum Promaxx...compression ratio is about 9.5-1...
A couple years back I had the 69 Dart down...stock stroke 340 and it ran 12.32 at 109...
The Duster near dead hooks on the street...leaves harder and pulls harder than the 340 in the Dart did...especially in high gear...but at 416 cu.in. it should...
Just curious what everybody thought...
Cab the track conditions should be good as there is some type of a Super Stock Show this w/e...Temps are supposed to be in the high 50's...
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2712329
11/03/19 09:54 AM
11/03/19 09:54 AM
Virginia
M Stall Offline
M Stall  Offline
Virginia
What did it run?
Re: 1st trip to the track this Saturday...what will it run? [Re: M Stall] #2712404
11/03/19 01:09 PM
11/03/19 01:09 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Originally Posted by M Stall
What did it run?
Yes!
Very interested to know as my Demon is very close to your combo.
Hope all went well!
Re: 1st trip to the track this Saturday...what will it run? [Re: wkroncke17] #2712616
11/04/19 10:31 AM
11/04/19 10:31 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Trying to resize some pictures and the pics of the ET slips...
Car went a best of 11.66 at 113 mph...
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2712625
11/04/19 10:49 AM
11/04/19 10:49 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
So I went at this the first run not really abusing it too hard...Left the line a little easy...rolled out a little early...
2nd run a little harder off the line trying to leave at an idle and ran through the end on the rug...
3rd run I ran up on the convertor some and that was the best run of all...
Last pass I ran up higher on the convertor...then shifted the 2-3 a little early I think...
A couple things I need to change...
There is no tach or shift light as he didn't want one in the car...
There's no way to really hear what a car is doing when running through closed exhaust and a helmet when the guy beside you has open headers...it makes it really hard to hear your own RPM's...
We ran it just like it runs everyday on the street with no changes...
After getting there and trying on a full face helmet Dad didn't want to run it through...He hasn't made a pass at the track since 1973...I've only made 8 passes since 1988...
I just noticed...The time slips are labeled wrong as the #3 should be #2 and #2 should be #3...
Someone who does this all of the time will be able to diagnose what everything really means...
I thought it was a little weird that you can gain 3/10's without gaining any mph... shruggy
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2712632
11/04/19 11:12 AM
11/04/19 11:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
One answer, 60ft. Look at the back half numbers 4.3134 vs 4.3473. Within .034. Same power. Accelerated quicker down low.
Doug
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2712702
11/04/19 02:38 PM
11/04/19 02:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What type of event was it at Mason-Dixon, and how was the track prep?
Re: 1st trip to the track this Saturday...what will it run? [Re: BradH] #2712712
11/04/19 03:24 PM
11/04/19 03:24 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Test and Tune for a Super Stock Show on Sunday...
I'd say track prep was very good...
A few friends who race regularly were there and commented about how well they kept up with the track...
...FAFO...
Re: 1st trip to the track this Saturday...what will it run? [Re: dvw] #2712721
11/04/19 03:49 PM
11/04/19 03:49 PM
an8sec70cuda Offline
Doug
iagree Exactly. Car runs strong!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1st trip to the track this Saturday...what will it run? [Re: skicker] #2713128
11/05/19 07:55 PM
11/05/19 07:55 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Stick a shift light where the " fasten seat belt" light is.
Re: 1st trip to the track this Saturday...what will it run? [Re: forphorty] #2713203
11/05/19 11:02 PM
11/05/19 11:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Solid!
'63 Dodge 330
11.19 @ 121 mph
Re: 1st trip to the track this Saturday...what will it run? [Re: GY3] #2714419
11/10/19 01:33 AM
11/10/19 01:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice going. up I will say that I always run my car through the full exh and I almost always shift by the feel of the car as I hardly ever look at the tach going down the track. And my old tach don't even have a shift lite. I can just tell by how the car is pulling when I want to shift even when I cant hear the eng to much if an open header car is next to me. But good luck with that cool Duster. Ron
