Re: 1969 Barracuda M code
[Re: davesmopars]
#2711282
10/30/19 02:58 PM
10/30/19 02:58 PM
Posts: 21,474 N.E. OHIO, USA
A12
N.E. OHIO, USA
I am handling the 1969 Barracuda M Code Registry for now. I have all the info now formally Dave Goodwin and Tom Wenstadt Any car or info let me know Thanks Dave Dave do you have a website and a link or did I miss that? Thanks MikeR (#8 M-Code Dart GTS on the GTS registry)
[Re: A12]
#2711332
10/30/19 05:51 PM
10/30/19 05:51 PM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
I am handling the 1969 Barracuda M Code Registry for now. I have all the info now formally Dave Goodwin and Tom Wenstadt Any car or info let me know Thanks Dave Dave do you have a website and a link or did I miss that? Thanks MikeR (#8 M-Code Dart GTS on the GTS registry) Mike, I have been working on getting one. Dave
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: Rhinodart]
#2838036
10/27/20 04:00 PM
10/27/20 04:00 PM
A12
N.E. OHIO, USA
Just thought I'd bring this back around because: Jim I pulled the M-Code Dart out of storage and hoping to do a few things over the winter to get it (maybe ) on the track sometime next year. Lots of undoing the inner fender well header cut outs (have original sheet metal for both sides) and the transmission and console floor tunnel for when it was converted to a 4-speed. Has the original 3.91 rear and have two of most everything to chose from. Still thinking it looks more like F5 than F8 but no big deal it's still going to stay GREEN.....with a black interior (original). Undecided about the black vinyl but will probably stay and even though it's a "stripe delete" I always wanted a black tail stripe so that may go on............and still leave the front fender GTS callouts. Here's what I have for a K-frame, what do you think? Does it look like an M-Code (big block) original K-frame........................and then there's that F5/F8 green paint Mike
[Re: A12]
#2838155
10/27/20 10:29 PM
10/27/20 10:29 PM
Posts: 43,459 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here is the k-frame in my 69 GTS. Looks F5 to me...
JB Rhinehart, Realist
A-Body's RULE!
[Re: A12]
#2838163
10/27/20 10:46 PM
10/27/20 10:46 PM
Posts: 1,651 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
My car is F5 body color with F8 upper and lower door frames. This photo shows original factory paint F8 lower door frame at right. In the center of the photo, F5 and F8 are next to each other, showing that the factory first painted the whole car and door F5 then masked around the door frames, then painted the door frames F8.
[Re: davesmopars]
#2838172
10/27/20 11:32 PM
10/27/20 11:32 PM
Posts: 8,193 fredericksburg,va
cudaman1969
fredericksburg,va
1969 M code Numbers matching needs a lot of work You need a fan shroud. M-codes came with solid black grills not painted. If you have painted one they where replaced at sometime
[Re: Rhinodart]
#2848593
11/19/20 12:18 PM
11/19/20 12:18 PM
A12
N.E. OHIO, USA
M-Code Dart GTS was number 10, that's all I care about... Was the criteria for making the list "back in the day" magazine road test articles?? If so then from the "50 Fastest" list I've seen and the June 1969 Drag Racing Magazine test the Dart GTS 440 M-Code should be listed as the SECOND fastest and FIRST QUICKEST real 4/5 passenger MUSCLE CAR of that era ! Check it out Jim E/T 12.70 @ 112 MPH Mike
[Re: cudaman1969]
#2852334
11/27/20 09:07 PM
11/27/20 09:07 PM
Posts: 1,401 northeast ohio
hulmule
northeast ohio
Owned a 69Dart GTS 383 4 speed car. Hated the light green color... They dropped the ball IMO on making a rally dash for Darts , at least GTS cars. Like the look of Cuda rally and wish M codes were a stick car. Would like to build a 69 Dart GTS clone. 440 -4 speed, rally gauges from a 70 swinger. maybe a couple other mods.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
