Re: Which Master Cylinder to use?
[Re: MoparJason0O0]
#2710877
10/29/19 10:04 AM
10/29/19 10:04 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Look at Dr. Diff's page. He has some master cylinder packages that are a great value. I have his setup on my 68 Barracuda with wilwood discs all around and it works very well.
He has a kit that comes with an adapter from 4-2 bolt and a 2 bolt aluminum master. I did find it necessary to buy his adjustable push rod as well.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#2711034
10/29/19 09:43 PM
10/29/19 09:43 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
He has a kit that comes with an adapter from 4-2 bolt and a 2 bolt aluminum master. I did find it necessary to buy his adjustable push rod as well. I’m about to need one for my Demon also, thanks to the OP. Badfish, is this the m/c you’re speaking of? https://www.doctordiff.com/aluminum-master-cylinder-kit.html
[Re: Bad340fish]
#2711072
10/29/19 11:54 PM
10/29/19 11:54 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
He has a kit that comes with an adapter from 4-2 bolt and a 2 bolt aluminum master. I did find it necessary to buy his adjustable push rod as well. Totally agree.
[Re: markz528]
#2711252
10/30/19 01:47 PM
10/30/19 01:47 PM
Posts: 5,097 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
After talking to Dr. Diff he recommended using a 15/16" bore m/c on the Duster with 4 wheel disc brakes...Mine are Wilwood... I used the same m/c and 4-2 bolt plate on the 69 Dart with factory 76 A Body disc brakes and 10.5" drums on the rear... Both cars stop excellent with good pedal feel...
...FAFO...
