Dyno Time Finally RESULTS IN #2710720
10/28/19 06:29 PM
10/28/19 06:29 PM
It's Complicated
HDNMOPERS Offline OP
It's Complicated
Finally getting to dyno my engine. Will be on the dyno at Precision Machine Service in Pigeon Forge Tn tomorrow morning. Go on their FB if you want see other dyno runs they have done. Hoping Matt Hensley can make it to kinda over see the dyno session. Since he did the build. The guess the number game is on. 100% street engine build for now. May change cams later. If I want it a little more street rowdy. So here's the build.
Low Deck 512
Molner crank and rods Diamond dished pistons 10.3 comp
Trick Flow 240s ported by Larry Smith B3 geometry correction 1.6 RAU rockers
M1 single plane ported by Larry Smith
850 Thumper Carb
Dwayne Porter spec Solid FT cam 112 LSA in at 108 Int 244@50 .555 lift Ex 252@50 .564 Lift
Dyno headers are 2 inch. Only size he had
Little Surprised it didn't pull any further than it did. HP about 5 over what I had in my head. TQ is about 40 over what I thought it would be. We only pulled to 5700 cause it just didn't make anymore after 5400-5500. Messed with some timing and jetting. It's safe and will tune more once it's in the car. Just had him print out to peak. Thanks to all involved Matt and Ken Hensley Dominic Thumper Dwayne Porter Larry Smith and Mike Beachal
Re: Dyno Time Finally [Re: HDNMOPERS] #2710732
10/28/19 07:01 PM
10/28/19 07:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
600
Re: Dyno Time Finally [Re: CSK] #2710744
10/28/19 07:25 PM
10/28/19 07:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Matt Hensley and his dad are two fine people with great attention to detail.
Bet you will be happy
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dyno Time Finally [Re: HDNMOPERS] #2710761
10/28/19 08:14 PM
10/28/19 08:14 PM
Washington
madscientist Offline
Washington
Low Deck 512
850 Thumper Carb
Only thing that jumps out at me is the small carb. I'm surprised Dom didn't talk you into a dominator.
Everything else looks pretty dang nice. A Porter cam, a quality cylinder head guy and you fixed the geometry. Everything to like.
On pump gas, 600-620 should be pretty easy.
Re: Dyno Time Finally [Re: B3422W5] #2710764
10/28/19 08:23 PM
10/28/19 08:23 PM
It's Complicated
It's Complicated
Absolutely they are. They were very helpful through out the whole build. Very cool to talk with Ken an Matt about the SS Hemi stuff and the Allen Johnson pro stock stuff.
Re: Dyno Time Finally [Re: madscientist] #2710765
10/28/19 08:31 PM
10/28/19 08:31 PM
It's Complicated
It's Complicated
Funny you say that about Dominic. We talked about a Dominator. We decided to go with the 850 for now with the option to a bigger carb later.
Re: Dyno Time Finally [Re: HDNMOPERS] #2710766
10/28/19 08:33 PM
10/28/19 08:33 PM
New York, USA
Chargerfan68 Offline
New York, USA
I guess 645hp. Any idea of head flow numbers? It sure has everything going for it. Best of luck!
Re: Dyno Time Finally [Re: HDNMOPERS] #2710784
10/28/19 09:23 PM
10/28/19 09:23 PM
The dyno results will depend on how good the air is their tomorrow, I know most dyno correct to a SAE standard so ask them to give you the actual as well as the corrected results to compare both. scope up
If it doesn't make more than 630 HP. and 670+ Ft lbs. torque something is amiss I fear twocents work
Let us know the air fuel results are also please up Are you going to do carb (jetting) and engine timing tuning tests also?
I'm thinking between 12.8 to 13.5 AFR will be near the best on pump gas luck scope
Re: Dyno Time Finally [Re: Cab_Burge] #2710790
10/28/19 09:50 PM
10/28/19 09:50 PM
It's Complicated
It's Complicated
Yes will be some carb and timing tuning.
Re: Dyno Time Finally [Re: HDNMOPERS] #2710795
10/28/19 10:12 PM
10/28/19 10:12 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
610@5800
Re: Dyno Time Finally [Re: mopar dave] #2710811
10/28/19 11:59 PM
10/28/19 11:59 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Peak torque of 660 at 5600
Peak HP of 633 at around 6500
Just some educated guesses. I have ran a few if Larrys across the dyno....Might make more but the street will love that thing. Great out of the gate. Low RPM torque will be impressive.
Todd
Re: Dyno Time Finally [Re: sasquatch] #2710912
10/29/19 11:52 AM
10/29/19 11:52 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
If the motor made 660tq@5600....... that would be 703hp at the same rpm.
I really try not to “race dyno’s”, since there can be a lot of factors that influence the final results, but I’ll put it this way......
If I were testing it here with 2” headers, I’d be looking for 650-660tq in the 46-4800 range and about 630-640hp peak in the 6000-6300 range.
I haven’t run anything yet myself with the TF heads at all..... so just pure speculation on my part.
I’ve added a few hundred rpm to the peaks on my guesses based on the added porting of the heads and the intake being ported.
Otherwise, stroker BB Mopars with short cams and std port heads usually peak pretty early.
The cam is small, based on what the original criteria was for where the motor was going to end up and how it would be used.
If the goal were just to make a big number.......there’s certainly easy power to be made by swapping to a longer duration cam.
Re: Dyno Time Finally [Re: fast68plymouth] #2710937
10/29/19 02:09 PM
10/29/19 02:09 PM
AndyF Offline
AndyF  Offline
That engine is similar to the 496 inch engine in my Coronet. My engine made 613 hp at 5800 and 631 torque at 4800.
Re: Dyno Time Finally [Re: AndyF] #2710954
10/29/19 03:17 PM
10/29/19 03:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
If the hp ends up peaking closer to your 5800 as opposed to 6000-6300....... then I’d expect the hp number to be lower than what I predicted.
I’d be pretty surprised if it couldn’t make 650ft/lbs........ how far up the power curve it can hang on to it with the small cam is the question mark for me.
Like I said...... I nudged the peak rpm up a bit because of the porting.
Re: Dyno Time Finally [Re: fast68plymouth] #2710975
10/29/19 05:10 PM
10/29/19 05:10 PM
AndyF Offline
AndyF  Offline
Could happen, just depends on how well the parts are matched. I have a TF intake on my engine which is a better design than the M1 but a ported M1 might work pretty good. My cam is a hyd roller and a touch smaller but it all depends on the combo. The TF heads work pretty well with some cams and don't work so well with other cams. Who knows how those heads will work once they've been ported. If all the parts are working together then it could be a 625/650 engine.
Re: Dyno Time Finally [Re: AndyF] #2711007
10/29/19 07:34 PM
10/29/19 07:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Is there a reason they stopped the pulls so low?
Carb looks like it goes pretty rich within a few hundred rpm at the top of the pull.
3 columns of data agree..... bsfc, fuel flow, a/f ratio.
Pretty big numbers though.
Re: Dyno Time Finally [Re: fast68plymouth] #2711012
10/29/19 07:46 PM
10/29/19 07:46 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
nice number . very small cam for a 512 . be great in a heavy street car or truck .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Dyno Time Finally [Re: fast68plymouth] #2711015
10/29/19 07:59 PM
10/29/19 07:59 PM
It's Complicated
It's Complicated
Dwayne we pulled to 5700 it just didn't make anymore above 5400-5500. I had him just print to peak. Yeah talk to Dominic after about it going rich on top. Had no phone reception where the dyno was at. He told me what it was most likely doing and what to change. Just wish we could of talked during the session.
Re: Dyno Time Finally [Re: tex013] #2711016
10/29/19 08:00 PM
10/29/19 08:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Tex
My combo is very similar! Don't make the mistake of a loose converter or deep gears.
Mine is so much fun on the street and we have a ball racing it as well.
'63 Dodge 330
11.19 @ 121 mph
Re: Dyno Time Finally [Re: HDNMOPERS] #2711017
10/29/19 08:09 PM
10/29/19 08:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
My guess is, had you been able to get the fuel curve straightened out, it would have hung on a bit better.
Even with it going pretty rich several lines earlier than 5400, the numbers were still trending upwards.
Were the headers dyno headers, regular headers, or fenderwell headers?
No dyno shop carb on hand to try?
