Re: Dyno Time Finally
[Re: CSK]
#2710744
10/28/19 07:25 PM
10/28/19 07:25 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
Matt Hensley and his dad are two fine people with great attention to detail. Bet you will be happy
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: HDNMOPERS]
#2710761
10/28/19 08:14 PM
10/28/19 08:14 PM
Posts: 4,457 Washington
madscientist
Washington
Finally getting to dyno my engine. Will be on the dyno at Precision Machine Service in Pigeon Forge Tn tomorrow morning. Go on their FB if you want see other dyno runs they have done. Hoping Matt Hensley can make it to kinda over see the dyno session. Since he did the build. The guess the number game is on. 100% street engine build for now. May change cams later. If I want it a little more street rowdy. So here's the build. Low Deck 512 Molner crank and rods Diamond dished pistons 10.3 comp Trick Flow 240s ported by Larry Smith B3 geometry correction 1.6 RAU rockers M1 single plane ported by Larry Smith 850 Thumper Carb Dwayne Porter spec Solid FT cam 112 LSA in at 108 Int 244@50 .555 lift Ex 252@50 .564 Lift Dyno headers are 2 inch. Only size he had Only thing that jumps out at me is the small carb. I'm surprised Dom didn't talk you into a dominator. Everything else looks pretty dang nice. A Porter cam, a quality cylinder head guy and you fixed the geometry. Everything to like. On pump gas, 600-620 should be pretty easy.
[Re: B3422W5]
#2710764
10/28/19 08:23 PM
10/28/19 08:23 PM
Posts: 149 It's Complicated
HDNMOPERS
It's Complicated
Absolutely they are. They were very helpful through out the whole build. Very cool to talk with Ken an Matt about the SS Hemi stuff and the Allen Johnson pro stock stuff.
[Re: HDNMOPERS]
#2710766
10/28/19 08:33 PM
10/28/19 08:33 PM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
I guess 645hp. Any idea of head flow numbers? It sure has everything going for it. Best of luck!
[Re: mopar dave]
#2710811
10/28/19 11:59 PM
10/28/19 11:59 PM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Peak torque of 660 at 5600 Peak HP of 633 at around 6500 Just some educated guesses. I have ran a few if Larrys across the dyno....Might make more but the street will love that thing. Great out of the gate. Low RPM torque will be impressive. Todd
[Re: sasquatch]
#2710912
10/29/19 11:52 AM
10/29/19 11:52 AM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Peak torque of 660 at 5600 Peak HP of 633 at around 6500 If the motor made 660tq@5600....... that would be 703hp at the same rpm. I really try not to “race dyno’s”, since there can be a lot of factors that influence the final results, but I’ll put it this way...... If I were testing it here with 2” headers, I’d be looking for 650-660tq in the 46-4800 range and about 630-640hp peak in the 6000-6300 range. I haven’t run anything yet myself with the TF heads at all..... so just pure speculation on my part. I’ve added a few hundred rpm to the peaks on my guesses based on the added porting of the heads and the intake being ported. Otherwise, stroker BB Mopars with short cams and std port heads usually peak pretty early. The cam is small, based on what the original criteria was for where the motor was going to end up and how it would be used. If the goal were just to make a big number.......there’s certainly easy power to be made by swapping to a longer duration cam.
[Re: AndyF]
#2710954
10/29/19 03:17 PM
10/29/19 03:17 PM
fast68plymouth
So. Burlington, Vt.
If the hp ends up peaking closer to your 5800 as opposed to 6000-6300....... then I’d expect the hp number to be lower than what I predicted.
I’d be pretty surprised if it couldn’t make 650ft/lbs........ how far up the power curve it can hang on to it with the small cam is the question mark for me. Like I said...... I nudged the peak rpm up a bit because of the porting.
[Re: AndyF]
#2711007
10/29/19 07:34 PM
10/29/19 07:34 PM
fast68plymouth
So. Burlington, Vt.
Is there a reason they stopped the pulls so low?
Carb looks like it goes pretty rich within a few hundred rpm at the top of the pull.
3 columns of data agree..... bsfc, fuel flow, a/f ratio.
Pretty big numbers though.
[Re: fast68plymouth]
#2711012
10/29/19 07:46 PM
10/29/19 07:46 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
nice number . very small cam for a 512 . be great in a heavy street car or truck .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2711015
10/29/19 07:59 PM
10/29/19 07:59 PM
HDNMOPERS
It's Complicated
Dwayne we pulled to 5700 it just didn't make anymore above 5400-5500. I had him just print to peak. Yeah talk to Dominic after about it going rich on top. Had no phone reception where the dyno was at. He told me what it was most likely doing and what to change. Just wish we could of talked during the session.
[Re: tex013]
#2711016
10/29/19 08:00 PM
10/29/19 08:00 PM
Posts: 4,651 Wichita
GY3
Wichita
Tex My combo is very similar! Don't make the mistake of a loose converter or deep gears. Mine is so much fun on the street and we have a ball racing it as well.
[Re: HDNMOPERS]
#2711017
10/29/19 08:09 PM
10/29/19 08:09 PM
fast68plymouth
So. Burlington, Vt.
Dwayne we pulled to 5700 it just didn't make anymore above 5400-5500. I had him just print to peak. Yeah talk to Dominic after about it going rich on top. Had no phone reception where the dyno was at. He told me what it was most likely doing and what to change. Just wish we could of talked during the session. My guess is, had you been able to get the fuel curve straightened out, it would have hung on a bit better. Even with it going pretty rich several lines earlier than 5400, the numbers were still trending upwards. Were the headers dyno headers, regular headers, or fenderwell headers? No dyno shop carb on hand to try?
