Which Master Cylinder to use? #2710581
10/28/19 11:19 AM
10/28/19 11:19 AM
Memphis, TN
MoparJason0O0 Offline OP
Memphis, TN
69 Dart Bracket race car.
I am currently using just a regular NAPA MC and need to switch it out. It is a 4 bolt, any suggestions on what to use or switch to?
Jason
Re: Which Master Cylinder to use? [Re: MoparJason0O0] #2710804
10/28/19 10:38 PM
10/28/19 10:38 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Discs? Drums? Disc/Drum?
Re: Which Master Cylinder to use? [Re: markz528] #2710865
10/29/19 09:09 AM
10/29/19 09:09 AM
Memphis, TN
Memphis, TN
All Disc
Re: Which Master Cylinder to use? [Re: MoparJason0O0] #2710877
10/29/19 10:04 AM
10/29/19 10:04 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Look at Dr. Diff's page. He has some master cylinder packages that are a great value. I have his setup on my 68 Barracuda with wilwood discs all around and it works very well.
He has a kit that comes with an adapter from 4-2 bolt and a 2 bolt aluminum master. I did find it necessary to buy his adjustable push rod as well.
68 Barracuda Formula S 340
Re: Which Master Cylinder to use? [Re: Bad340fish] #2711034
10/29/19 09:43 PM
10/29/19 09:43 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I’m about to need one for my Demon also, thanks to the OP.
Badfish, is this the m/c you’re speaking of?
https://www.doctordiff.com/aluminum-master-cylinder-kit.html
Re: Which Master Cylinder to use? [Re: Bad340fish] #2711072
10/29/19 11:54 PM
10/29/19 11:54 PM
Morrow, OH
Morrow, OH
Totally agree.
Re: Which Master Cylinder to use? [Re: markz528] #2711252
10/30/19 01:47 PM
10/30/19 01:47 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
After talking to Dr. Diff he recommended using a 15/16" bore m/c on the Duster with 4 wheel disc brakes...Mine are Wilwood...
I used the same m/c and 4-2 bolt plate on the 69 Dart with factory 76 A Body disc brakes and 10.5" drums on the rear...
Both cars stop excellent with good pedal feel... twocents
...FAFO...
