Oil Pressure Sending Unit Placement
#2710356
10/27/19 11:52 AM
10/27/19 11:52 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I am working on the wiring for my 5.7 Hemi in to the 64 wagon project. I need to add a sending unit for an aftermarket oil pressure gage. I still need to use the stock oil pressure and oil temp sensors for the computer. Any one else added another sending unit? There looks to be another port above the oil temp sender on the block. Can I use this port for oil pressure? Is there a better place to add a sender?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Oil Pressure Sending Unit Placement
[Re: rattler]
#2710545
10/28/19 08:54 AM
10/28/19 08:54 AM
Posts: 112 Katy, TX
Bakaruda
Katy, TX
Just above the oil filter you will see 2 plugs. If you remove one of them this is where I have mine. Sorry I don't have any pictures of it.
1969 Barracuda GENIII Hemi 2019 Ram 1500 Laramie
[Re: Bakaruda]
#2710701
10/28/19 05:29 PM
10/28/19 05:29 PM
rattler
Crofton, Ky.
Thanks. That's the one I thought would work best.
[Re: rattler]
#2711431
10/30/19 09:52 PM
10/30/19 09:52 PM
Posts: 308 Ontario, Canada
RealWing
Ontario, Canada
This is my installation on my 6.1 Hemi Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2015 BMW K1600 GTL
