Nitrous,,,any expets here? #2709352
10/22/19 10:55 PM
10/22/19 10:55 PM
Great Neck,LI,new york
hemi-itis Offline OP
I want to cool my roots blower with a pair of N2o plates added to the exsisting 1 inch spacer,that did not work as the blade on the SV1 comes out a little more than 2 1/4 inches under thecarb base.I would need a 2 1/8 spacer that patrick says it too much and suggested the perimeter plates.They are well over $300 each! I m thinking a fogger nozzle in each spacer,just have to find out if one per carb is or do I need 2 per work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Nitrous,,,any expets here? [Re: hemi-itis] #2709392
10/23/19 07:42 AM
10/23/19 07:42 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I responded on the facebook page.....
Call induction solutions, they were working on a plate for that carb a while ago.
If there is no perimeter plate available, then get someone (Induction solutions) to plumb you a few direct port nozzles in a spacer.
You might also get Nova Joe to plumb it for you
....BAD A$$ STREET CAR.....
Re: Nitrous,,,any expets here? [Re: n20mstr] #2709587
10/23/19 05:01 PM
10/23/19 05:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Put it on alcy
Re: Nitrous,,,any expets here? [Re: hemi-itis] #2709628
10/23/19 07:30 PM
10/23/19 07:30 PM
What about one of the Snow water methanol injection kit on straight methanol?
Re: Nitrous,,,any expets here? [Re: Cab_Burge] #2709698
10/24/19 01:17 AM
10/24/19 01:17 AM
Oh,they make preimeter plates for over $300 each.Just not in the budget..................I'm thinking a fogger nozzle into each carb spacer, just have to figure out the style nozzle and jetting.
Re: Nitrous,,,any expets here? [Re: n20mstr] #2709699
10/24/19 01:19 AM
10/24/19 01:19 AM
I have everything except the nozzles.Plumbing is easy,just have to get 2 nozzles.
I had been looking at Snow & IAS for some time and decide gas it the coolest option,much lower IAT that W/m or straight meth.
Re: Nitrous,,,any expets here? [Re: hemi-itis] #2709718
10/24/19 07:57 AM
10/24/19 07:57 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Spray whatever you like in there, but at the end of the day, nothing will be as good as methanol. Get a pair of rupert alky carbs if you're staying with carbs.Then you can spin it till you run over the crank if you like lol.
Re: Nitrous,,,any expets here? [Re: hemi-itis] #2709727
10/24/19 09:04 AM
10/24/19 09:04 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted by hemi-itis
I want to cool my roots blower with a pair of N2o plates added to the exsisting 1 inch spacer,that did dot work as the blade on the SZ1 comes out a little more tha 2 1/4 inches.I would need a 2 1/8 sapacer that patric says it too much and suggested the perimeter plates.They are well over $300 each! I m thinking a fogger nozzle in each spacer,just have to find out i per car is or do I need 2 per work
You are the only guy that I know that bought those carbs and still run them. Most guys gave up on them LONG ago.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Nitrous,,,any expets here? [Re: hemi-itis] #2709773
10/24/19 12:58 PM
10/24/19 12:58 PM
an8sec70cuda Offline
Did you put silicone on the nitrous plate?????
I haven't seen an SV1 on a car at the track in a while now that I think of it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Nitrous,,,any expets here? [Re: an8sec70cuda] #2709972
10/25/19 11:19 AM
10/25/19 11:19 AM
[quote=an8sec70cuda]Did you put silicone on the nitrous plate?????
/quote]
Yes,that is silicone and not by me laugh2 Helpers try to help but left UNattended things like this happen. I had a police tow and left to come back and find that eek
I cleaned it up and put it back together with the SUPERPERMFORMANCE gaskets only to find the blade hit the crossbars..............
I do have a pair of Dominators lined up to borrow and try.That are off a 600ci raceboat with 2 engines. I'm a low budget mostly NO budget exhibitionist just trying to go fast so I just kept working on these carbs.
They seem to be good,,,,,just not GREAT!
I mostly street drive and try to get to the track 3 or 4 times a year.This has been a lean year getting out to Atco only one time and don't think I can make it out before seasons end. The auto biz sure has changed the last few years!
Re: Nitrous,,,any expets here? [Re: dthemi] #2709974
10/25/19 11:24 AM
10/25/19 11:24 AM
I don't know how well that would work out for street driving.I can drive on pump premium and still go high 9's. Meth or "E" burns at a much faster rate requiring more fuel stops,so I stay with gas and step up to 112 for the race daze.
