School Me on Distributor Caps
#2709655
10/23/19 08:54 PM
10/23/19 08:54 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I have a box of distributor caps and cant figure out which is which. Does anyone know how to identify the difference between electronic caps and point caps?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: School Me on Distributor Caps
[Re: MoparMike1974]
#2709690
10/23/19 11:24 PM
10/23/19 11:24 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
AFAIK cap is the same for points and electronic. Generally true. Exception are the dual point - prestolite caps, which are also used for the direct Connection magnetic pickup race ditributor (aka tsach drive distributor) They have spring loaded carbon centerthat contacts the rotor.
[Re: RSI700VIPER]
#2709694
10/23/19 11:47 PM
10/23/19 11:47 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
The ones with the floating carbon plug hooked to a spring is the Hi Po cap for the race and Hi Po distributors, both points and electronic. You need the rotor to match it also which has a flat brass piece form the outer edge into the contact in the center of the rotor with the carbon plug The other cap is for the non Hi Po distributors with the rotor that has the raised of thin metal flexable tab in the center to touch the pointed tip going through that cap to the coil wire contact
