Is a 68-69 SB and BB B body K member different? #2709187
10/22/19 01:13 PM
10/22/19 01:13 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I am trying to confirm but I never think about it when I'm at my shop, I remember being told there is no difference between a small block and big block K member in 68_69 B bodies. IN fact 70 may be the same and the difference in a 71 is the tilt of the steering gear box or maybe that change was in 70. So how much of this is true?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Is a 68-69 SB and BB B body K member different? [Re: mopar346] #2709205
10/22/19 02:07 PM
10/22/19 02:07 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Re: Is a 68-69 SB and BB B body K member different? [Re: mopar346] #2709206
10/22/19 02:09 PM
10/22/19 02:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The only BB and SB K member difference was on 73 and lates B body
Re: Is a 68-69 SB and BB B body K member different? [Re: NachoRT74] #2709228
10/22/19 03:43 PM
10/22/19 03:43 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks folks.
Re: Is a 68-69 SB and BB B body K member different? [Re: mopar346] #2709343
10/22/19 10:08 PM
10/22/19 10:08 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That chart listed in the link isn't entirely correct. V8 K frames are not the same for 66 - 72 B and E bodies. Yes, the engine mounts are the same, but the angle that the steering box sits is different. I used to think that was BS until I set up a jig, and mounted 3 different k frames from 66 - 70 B bodies, and measured the angle of the steering box mount. They were all the same. I then mounted 3 different E body k frames to the same jig that had not been moved, and all 3 steering box angles were the same. BUT....there was a 3 degree difference in the angle between the B and E k frames where the steering box mounts. Would you notice a difference if you mounted an E body k frame in a B body, or vice versa? Probably not, but back in the day when they were just cars....you may have worn the steering coupler out after a lot of miles had the same swap been done. There's some more useless information to cloud your brain....lol.
Re: Is a 68-69 SB and BB B body K member different? [Re: JDMopar] #2709589
10/23/19 05:12 PM
10/23/19 05:12 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Mmmm... dunno if 3 degrees angle is really a difference to be considered as a diff part. Why I say this? My 74 Charger ( yes I know, a diff monster ) got aligment shims between steering box and K member. So those 3 degrees could be considered as a tolerance when part is being manufactured, able to be corrected when assembling.
We know our cars are not a piece of art on precision at factory. Just looking at the low quality of welding seams of K members you can tell it.
Re: Is a 68-69 SB and BB B body K member different? [Re: JDMopar] #2709640
10/23/19 08:00 PM
10/23/19 08:00 PM
A727Tflite Offline
A727Tflite  Offline
So how do you tell the difference between the B and E body k-frames?
I understand what you did I - but how do you verify when looking at the part?
And is that angle difference towards the side of the car or vertically to the floor?
Re: Is a 68-69 SB and BB B body K member different? [Re: A727Tflite] #2709649
10/23/19 08:40 PM
10/23/19 08:40 PM
mopar346 Offline OP
mopar346  Offline OP
I believe it is vertical and I cant answer to the difference between B and E
Re: Is a 68-69 SB and BB B body K member different? [Re: A727Tflite] #2709650
10/23/19 08:41 PM
10/23/19 08:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
68-69 B body K frame compared to E body is the sway bar mounting is very different
Re: Is a 68-69 SB and BB B body K member different? [Re: gtx6970] #2709653
10/23/19 08:49 PM
10/23/19 08:49 PM
mopar346 Offline OP
mopar346  Offline OP
True but is there a way to tell a 70-71 B from an E?
Re: Is a 68-69 SB and BB B body K member different? [Re: A727Tflite] #2709658
10/23/19 09:18 PM
10/23/19 09:18 PM
pgh pa
captaindodge Offline
pgh pa
That 3.5 degree increase is on the angle vertically to the floor. Ever notice someone driving an E-body and it looks like they are sitting on the floor. The E-body has a flatter steering angle column to match the lower seating.
Re: Is a 68-69 SB and BB B body K member different? [Re: mopar346] #2709829
10/24/19 04:54 PM
10/24/19 04:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No idea, never needed a K frame so never looked that hard at one to be honest
Re: Is a 68-69 SB and BB B body K member different? [Re: gtx6970] #2709845
10/24/19 06:17 PM
10/24/19 06:17 PM
mopar346 Offline OP
mopar346  Offline OP
grin
Me neither but I like info.
