motorhome 440 value #2708903
10/21/19 02:23 PM
10/21/19 02:23 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
1975 440 with the 727 bolted to it. 24,000 miles. been sitting but it does run. any idea on value for the engine/tranny combo?
Re: motorhome 440 value [Re: 2abodymcodes] #2708927
10/21/19 03:40 PM
10/21/19 03:40 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
$500 at best, probably less
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: motorhome 440 value [Re: oldjonny] #2708944
10/21/19 05:15 PM
10/21/19 05:15 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I see them advertised and sitting a long time at $1,500. I think with the 727 it is worth more than $500 though.
Re: motorhome 440 value [Re: BigBlockGTS] #2708957
10/21/19 05:51 PM
10/21/19 05:51 PM
Silsbee,Tx
-Cuda Offline
-Cuda  Offline
Silsbee,Tx
I just sold 440 and trans for $900 but it was a 71 hp motor.
Re: motorhome 440 value [Re: -Cuda] #2708964
10/21/19 06:03 PM
10/21/19 06:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I sold a 73 complete engine and trans out of a New Yorker last year for $1300. I did have a friend start it on his stand to make sure it was good. Motorhome engines can have funky heads and cooling systems, usually worth less than car 440's.
JB Rhinehart, Realist
A-Body's RULE!
Re: motorhome 440 value [Re: -Cuda] #2708965
10/21/19 06:03 PM
10/21/19 06:03 PM
Kirkland, Washington
Pacnorthcuda Offline
I think the $500 estimate is about right. It’s a 75 core motor. Ask $600, no more, if you want response.
Re: motorhome 440 value [Re: Pacnorthcuda] #2709082
10/22/19 05:54 AM
10/22/19 05:54 AM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
Trans are usually different than a car shorter so not much value in them .
Re: motorhome 440 value [Re: GVH] #2709088
10/22/19 07:05 AM
10/22/19 07:05 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Motor home trans have the basic 727 BB case so that is of value and many if not most have the 5 clutch drums so that's a big plus. Truck people can also use the trans as is and build the correct shaft so there is a draw there, I know someone who put an RV trans in a 73 Charger as is and just built a shaft. as a core the trans is worth $75-100. Engine can be all over the place but I know of several RV combos selling in the $800 range but I paid a $100 for a set up of a running 40k variety in the same time period. So in the end take what you can get and advertise it with room to come down cause you know they're gonna hit you up. twocents
Careful, your character's showing!
Re: motorhome 440 value [Re: mopar346] #2709366
10/22/19 11:05 PM
10/22/19 11:05 PM
Fargo ND
moparphilll Offline
moparphilll  Offline
Fargo ND
Most RV 440's have the Big Rods in them like the 6-pack motors
Re: motorhome 440 value [Re: moparphilll] #2709391
10/23/19 06:17 AM
10/23/19 06:17 AM
mopar346 Offline
mopar346  Offline
True but mixed opinions on whether that is a plus or not.
Re: motorhome 440 value [Re: 2abodymcodes] #2709415
10/23/19 08:32 AM
10/23/19 08:32 AM
usa
Mopar1970440 Offline
usa
Sold my last RV 440 a few years back for 350, it was was locked up due to water in the cylinders it had the short tail 727 attached. I believe most if not all RV 440s are steel crank engines.
Re: motorhome 440 value [Re: Mopar1970440] #2709451
10/23/19 10:01 AM
10/23/19 10:01 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Uncle Tony has a video recently of a guy with a motorhome 440 in a B body. All stock, except for a 671 Blower! and mild cam. Car was pretty quick in the 8th mile - and he had been driving it for 15 years. Search Uncle Tony's garage on Youtube - you should be able to find it.
If you can get the engine and trans for less than a grand, go for it. You can swap the tailshaft on the trans pretty easily.
1970 340 swinger. sublime 1967 barracuda fastback BB project 55 Plymouth Project
Re: motorhome 440 value [Re: 19swinger70] #2709452
10/23/19 10:04 AM
10/23/19 10:04 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Re: motorhome 440 value [Re: 19swinger70] #2709510
10/23/19 11:59 AM
10/23/19 11:59 AM
Shelby, Ohio
2
Shelby, Ohio
Thanks for all the responses.
damper thoughts running a gear drive
by moparx. 12/10/19 01:16 PM
AMC LIFTERS
by A/MP. 12/10/19 12:39 PM
Having foot surgery-shoe question
by Mastershake340. 12/10/19 12:27 PM
Valve lash kill and thrill
by Clanton. 12/10/19 12:06 PM
Moparts Recent Posts
issues with fresh 440
by lewtot184. 12/10/19 01:30 PM
Two 426 Hemis Complete
by RoadRunner. 12/10/19 01:28 PM
Stu Harmon memorial decals
by moparx. 12/10/19 01:27 PM
Poll: CUSTOM LICENSE PLATE OPTIONS! :)
by Cab_Burge. 12/10/19 01:22 PM
