Nitrous,,,any expets here?
#2709352
10/22/19 10:55 PM
10/22/19 10:55 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I want to cool my roots blower with a pair of N2o plates added to the exsisting 1 inch spacer,that did not work as the blade on the SV1 comes out a little more than 2 1/4 inches under thecarb base.I would need a 2 1/8 spacer that patrick says it too much and suggested the perimeter plates.They are well over $300 each! I m thinking a fogger nozzle in each spacer,just have to find out if one per carb is or do I need 2 per
Re: Nitrous,,,any expets here?
[Re: hemi-itis]
#2709392
10/23/19 07:42 AM
10/23/19 07:42 AM
Posts: 4,667 On the parachute mount
n20mstr
I responded on the facebook page.....
Call induction solutions, they were working on a plate for that carb a while ago.
If there is no perimeter plate available, then get someone (Induction solutions) to plumb you a few direct port nozzles in a spacer.
You might also get Nova Joe to plumb it for you
....BAD A$$ STREET CAR.....
[Re: hemi-itis]
#2709628
10/23/19 07:30 PM
10/23/19 07:30 PM
Posts: 43,088 Bend,OR USA
Cab_Burge
What about one of the Snow water methanol injection kit on straight methanol?
[Re: Cab_Burge]
#2709698
10/24/19 01:17 AM
10/24/19 01:17 AM
hemi-itis
Oh,they make preimeter plates for over $300 each.Just not in the budget..................I'm thinking a fogger nozzle into each carb spacer, just have to figure out the style nozzle and jetting.
[Re: n20mstr]
#2709699
10/24/19 01:19 AM
10/24/19 01:19 AM
hemi-itis
I have everything except the nozzles.Plumbing is easy,just have to get 2 nozzles. I had been looking at Snow & IAS for some time and decide gas it the coolest option,much lower IAT that W/m or straight meth.
[Re: hemi-itis]
#2709727
10/24/19 09:04 AM
10/24/19 09:04 AM
Posts: 20,141 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I want to cool my roots blower with a pair of N2o plates added to the exsisting 1 inch spacer,that did dot work as the blade on the SZ1 comes out a little more tha 2 1/4 inches.I would need a 2 1/8 sapacer that patric says it too much and suggested the perimeter plates.They are well over $300 each! I m thinking a fogger nozzle in each spacer,just have to find out i per car is or do I need 2 per You are the only guy that I know that bought those carbs and still run them. Most guys gave up on them LONG ago.
[Re: hemi-itis]
#2709773
10/24/19 12:58 PM
10/24/19 12:58 PM
Posts: 13,343 Marion, South Carolina [><]
an8sec70cuda
Did you put silicone on the nitrous plate?????
I haven't seen an SV1 on a car at the track in a while now that I think of it.
[Re: an8sec70cuda]
#2709972
10/25/19 11:19 AM
10/25/19 11:19 AM
hemi-itis
[quote=an8sec70cuda]Did you put silicone on the nitrous plate????? /quote] Yes,that is silicone and not by me Helpers try to help but left UNattended things like this happen. I had a police tow and left to come back and find that I cleaned it up and put it back together with the SUPERPERMFORMANCE gaskets only to find the blade hit the crossbars.............. I do have a pair of Dominators lined up to borrow and try.That are off a 600ci raceboat with 2 engines. I'm a low budget mostly NO budget exhibitionist just trying to go fast so I just kept working on these carbs. They seem to be good,,,,,just not GREAT! I mostly street drive and try to get to the track 3 or 4 times a year.This has been a lean year getting out to Atco only one time and don't think I can make it out before seasons end. The auto biz sure has changed the last few years!
[Re: dthemi]
#2709974
10/25/19 11:24 AM
10/25/19 11:24 AM
hemi-itis
Spray whatever you like in there, but at the end of the day, nothing will be as good as methanol. Get a pair of rupert alky carbs if you're staying with carbs.Then you can spin it till you run over the crank if you like lol. I don't know how well that would work out for street driving.I can drive on pump premium and still go high 9's. Meth or "E" burns at a much faster rate requiring more fuel stops,so I stay with gas and step up to 112 for the race daze.
