Isn't the filler on a 71 Charger behind the license plate? I thought most low filler necks used non-vented caps to keep fuel from leaking out under hard acceleration. There should be a vent tube on the fuel tank itself.
1971 B Body was Chrysler’s early attempt at emission control
There is a vapor separator inside the drivers side rear wheel well - Four hoses for venting run off the drivers side of the gas tank to this vapor separator
Then there is a fifth nipple off the vapor separator that runs all the way to the passenger side three nipple breather on the valve cover of engine
The factory gas cap was pressure vacuum or so called
The pressure vacuum gas cap is designed to vent small amounts of air into the car gas tank . The vented gas cap has a one-way release valve that is pressure-activated. When the pressure reaches a certain point (defined by so many pounds per square inch) the valve opens by a very small amount, relieving some of the pressure by allowing air into the gas tank , not out into the atmosphere
Drill a very tiny hole
Or do like I did and take one of the cheap stants that everyone sells , drill thru the inside plastic vent hole , and basically remove the seals and spring without drilling all the way through
But either way under hard acceleration
