Re: Need some opinions on which torque converter
[Re: 69ACME]
#2709108
10/22/19 09:07 AM
10/22/19 09:07 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I agree with all thats been said. If you aren't shooting for a great ET at the track, what is left is street manners, feel, and STREET TRACTION. By that i mean why put up with any less responsive converter when a real tight one will still fry the hides? Personally i would shoot for about 2600 to 2800 stall behind your motor. A converter that tight will move out smartly at the tip of the throttle like a stock 440 converter combo (only harder!) and be a blast to drive on the street. A good converter builder should know how tight you can go with the cam specs and other motor specs so it won't fall on its face from a dead stop.
[Re: jlatessa]
#2709132
10/22/19 10:28 AM
10/22/19 10:28 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depending on the cam specs(and low speed engine vacuum) a converter that’s too tight will lead to poor in-gear idle and very low speed characteristics, and possibly be keeping the motor operating in an area of the power band where it’s not quite “up on the cam” yet....... during normal “in town” driving situations.
Even my Honda Civic and 2500 Silverado 6.0 have converters loose enough where the engine is rarely below 2200 rpm driving around in town........ and those are 100% stock engines with tiny cams.
Frankly, with MW sized ports, I’d expect the motor to be happier with a little extra rpm(and the accompanying increased port velocity) that you’d get with a slightly loose converter while being driven around town.
Again, for me........ most of the deciding factors would be based on the cam specs and engine vacuum.
[Re: fast68plymouth]
#2709144
10/22/19 11:17 AM
10/22/19 11:17 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Thanks for the input FAST.
We were a little surprised that the engine nosed over so early, but either it ran out of carburetor or the dual plane was not the best pick for the engine. Forgot to check vacuum at full throttle to see if it was he carb...RATS!
Anyhow, we were pleased at the output, about 40 or 50 above our initial guesses so after a couple of jetting and timing changes we called it a day.
Torque peaked at 651 @ 4261, HP 620 @ 5543
Good TQ curve; 621 @ 2821
Does this help?
Joe
PS forgot that these numbers were with the Dyno's 1-3/4" test headers, went to put our 2" headers on and ran into fitment problems with the dyno so that may account for choking the engine somewhat.
[Re: jlatessa]
#2709148
10/22/19 11:22 AM
10/22/19 11:22 AM
fast68plymouth
So. Burlington, Vt.
I don’t see any cam specs. I would have checked the idle vacuum, along with the part throttle vacuum in the 2000-2800 range. Basically, at least initially.......it’s going to come down to you and a converter shop being on the same page about what you’re looking for...... and then seeing how it pans out after it’s in the car.
[Re: BradH]
#2709151
10/22/19 11:27 AM
10/22/19 11:27 AM
fast68plymouth
So. Burlington, Vt.
For a “hot” street motor, making good power is usually the easy part.
It’s making it really Street friendly, and fairly quirk free that’s often the hard part.
#2709155
10/22/19 12:02 PM
10/22/19 12:02 PM
Posts: 4,206 New York
polyspheric
New York
If you don't have power brakes (not enough idle vacuum), you'll find yourself wedging your knee under the steering wheel to hold the car at lights, or it will creep away on you. You will also be stopping the crank under low speed braking.
Boffin Emeritus
[Re: jlatessa]
#2709159
10/22/19 12:09 PM
10/22/19 12:09 PM
Posts: 1,317 Ohio
jlatessa
Ohio
Thank Polyspheric, I will definitely keep that in mind.
Joe
[Re: jlatessa]
#2709164
10/22/19 12:19 PM
10/22/19 12:19 PM
Posts: 1,317 Ohio
jlatessa
Ohio
OK, so much for my memory....
Bullet Racing Cams; Part No. 503000 Dur. @ .50 In. Ex. 257. 264. Lobe lift 4340. 4340. Separation 110. timing events .050 Int 22.5 OP, 54.5 Closed Ex 66 18 Duration @ .20 In 290 Ex 295 Gross lift 651/651 Lash hot .020 degree intake lobe to 106 10.7 CR, Pump gas (93)
Running a 275-60-15 rear for the street Have a Hoosier 10-1/2 we use on our 70 Charger to try on the RR just for some idea at the strip
[Re: jlatessa]
#2709196
10/22/19 01:28 PM
10/22/19 01:28 PM
fast68plymouth
So. Burlington, Vt.
That’s basically going to want something like a really tight 9.5”.
Flash should end up in the low-4000’s.
It’s likely going to need to idle at around 1000-1100 in gear....... maybe even slightly higher. It will be highly dependent on the timing curve and carb set-up.
In my mind that’s really more of a mild bracket race/hot street strip cam........as opposed to a mild-ish mostly street cam. Looks like it’s from the UD masters. Same grind I ran in my 448, but on a 108. Measures closer to 259@.050 with the Mopar sized base circle and .800 lifter wheels. My 448 was reasonably docile with it...... but I was running 4.56’s and a 5300 converter, with open headers. I’d expect the idling in gear vacuum to end up under 12”.
[Re: jlatessa]
#2709281
10/22/19 07:13 PM
10/22/19 07:13 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Have a 505 CI BB going into a 71 RR, I'm thinking 3800# or so.
Engine Dynoed at 620 HP and 650 torque flattening out around 5500 RPM 950 Holley, dual plane Indy max wedge on Eddy Victors.
Going to a Dana w/3.54s.
Car will go to the track maybe twice to sort out tires and suspension, but will be primarily street driven weekends to shows and meets.
I'm thinking a tight 11" 2600-3000 with furnace brazing and an anti ballooning plate.
Does this sound like a combo that will work?
Thanks in advance...Joe I don't like having a tight vert with my 448" .640 cam.mine stalls at 3k and drops to 4k on the shift 9.5 vert 3.73 d60 295- 50-15 M/T ET Street..I am looking at the same changes with vert,gear so I am watching this post to help.
[Re: jlatessa]
#2709405
10/23/19 08:59 AM
10/23/19 08:59 AM
gregsdart
Does this help?
Joe
PS forgot that these numbers were with the Dyno's 1-3/4" test headers, went to put our 2" headers on and ran into fitment problems with the dyno so that may account for choking the engine somewhat. That is great torque at 2800. A converter as tight as what came behind a 340 , 383 or street hemi(all the same k factor) should stall well over 3,000. I built a 535 with 906 heads many many years ago that pushed a stock converter like that to about 3600! Well, it did for the three runs i made before it ate itself😒. So you have some room here if you want a very responsive package and are willing to give up ultimate ET . A. Tight 11 inch might put the best smile on your face!
