Re: B-Body Drums to Disc Conversion
[Re: Keith Richards]
#2708697
10/20/19 10:45 PM
10/20/19 10:45 PM
Posts: 4,664 Wichita
GY3
Wichita
My car is gets a lot of street miles and see's the track as often as possible. I used the Wilwood Pro-Street kit with vented rotors. I absolutely love the way they work and the ease of install. They bolted right to the drum spindle, too.
I've done a couple of 130 mph passes and it comes down from those with ease. Car is 3,600+ lbs. with me.
[Re: GY3]
#2708701
10/20/19 10:50 PM
10/20/19 10:50 PM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
Thanks GY3, That is the brand and kit I was thinking as well, I am 3600# with me in the car as well.............. Just got to get the car here and make sure the current wheels fit around the calipers per there site, they are narrowed stock looking steel wheels to replicate a 69.5 RR 6 pack car.
#2708724
10/21/19 12:06 AM
10/21/19 12:06 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
I have been running the SSBC front brakes since 2007 , when I bought and imported the Plymouth . Had 10"rear drums , were fine till I started running 128+ . Now have rear discs , generic kit using Cadillac type calipers with handbrake , Metric GM caliper . Stops fine without fade now . No power booster .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: GY3]
#2708824
10/21/19 11:49 AM
10/21/19 11:49 AM
Posts: 277 MN
Willie68coronet
MN
I've done a couple of 130 mph passes and it comes down from those with ease. Car is 3,600+ lbs. with me. I'm looking at those also. Which diameter rotors did you get? 12 inch or?
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Willie68coronet]
#2708919
10/21/19 04:10 PM
10/21/19 04:10 PM
GY3
Wichita
8 My car is gets a lot of street miles and see's the track as often as possible. I used the Wilwood Pro-Street kit with vented rotors. I absolutely love the way they work and the ease of install. They bolted right to the drum spindle, too.
I've done a couple of 130 mph passes and it comes down from those with ease. Car is 3,600+ lbs. with me. I'm looking at those also. Which diameter rotors did you get? 12 inch or? I honestly don't recall off the top of my head, but 10.7" sounds correct? Bought them at least 6 years ago...
[Re: moparx]
#2708925
10/21/19 04:38 PM
10/21/19 04:38 PM
tex013
Sydney,Australia
what master cylinder bore, pedal ratio, and the diameter of the metric calipers ? TIA tex. Ok , master cylinder is the 1 supplied by SSBC with the front brake kit , I am pretty sure it is 1" I ran it with factory booster and now without booster . Has standard factory pedal ratio . The caliper is iron and I had to slightly clearance it to run my 10"wide rims , ok with 8's Caliper : https://www.circletracksupply.com/g...ar-disc-kits-on-pick-up-trucks-cars.htmlSimilar kit: https://www.performanceonline.com/M...-dana-60-Rear-Disc-Brake-Conversion-Kit/This looks like the kit I got : https://www.classicindustries.com/product/mp500551.htmlI did have some spacer plates cut ro replicate the thickness of the drum backing plate to keep offset correct and bearings/seals in correct position . The POL kit and MasterPower kits have this supplied if I understand correctly , but be aware of this . Andy is correct Cass (DRDiff) does have everything . He like a few others now use a mustang/ford rear caliper and a slightly smaller rotor . Cost of currency conversion plus freight stopped me buying these . Got my kit local unused for $400.00 . Seller showed me they were available , he bought them , on ebay Tex
[Re: AndyF]
#2709048
10/21/19 10:42 PM
10/21/19 10:42 PM
Keith Richards
Windsor ,Ca.
I'll look into that, Doctor Diff built the Dana 60 for me that's in the car still, back in about '06 or 7.
