3.3 belt tensioner alignment pin broke in engine #2708935
10/21/19 05:26 PM
10/21/19 05:26 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
What is the best way to get it out.
Its a 01 town and country 3.3 , its been screaming at me the last two days so I took out the idler and tensioner, only to realize it left the alignment down/pin broken off in the bloke. Its very tight fit, Probably can't get it with a drill, maybe chiseled an angle?
Re: 3.3 belt tensioner alignment pin broke in engine [Re: 71sat440] #2708975
10/21/19 07:11 PM
10/21/19 07:11 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Can you take the right front tire and splash shield off and go in that way? Might give you a straighter shot at it than from above.
The little dowel is aluminum, so i'd say carefully drilling it out would be the best. it's probably corroded in there pretty good.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
