Multi leaf springs and caltracs don’t work #2708882
10/21/19 02:14 PM
10/21/19 02:14 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
https://youtu.be/Dyd-k-gdeRU
1.41 60’ with the back tires. Probably was going to be a PB run if it stayed down.
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2708883
10/21/19 02:15 PM
10/21/19 02:15 PM
Dayton, OH
Dayton, OH
Picture was worth the broken ball joint.
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2708916
10/21/19 03:59 PM
10/21/19 03:59 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I couldn't get them to work with A-body SS 456/457 springs.
We went with split mono's and did a 1.38 60 ft. this weekend.
'63 Dodge 330
11.19 @ 121 mph
Re: Multi leaf springs and caltracs don’t work [Re: GY3] #2733229
01/15/20 08:40 AM
01/15/20 08:40 AM
Dayton, OH
Dayton, OH
It’s all on the shocks.
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2733270
01/15/20 10:04 AM
01/15/20 10:04 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Possibly. I didn't have adjustables then.
'63 Dodge 330
11.19 @ 121 mph
Re: Multi leaf springs and caltracs don’t work [Re: GY3] #2733281
01/15/20 10:21 AM
01/15/20 10:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Calvert did his R&D for CalTracs on a 4-speed Super Stock CJ Mustang w/ multi-leaf springs that were flatter & way stiffer than normal... I'd be surprised if those things barely flexed under load.
CalTracs and SS springs "fight" each other, unless you Band-Aid the sh!t outta the combination like IIRC Tony R (n2Omstr) did for a while.
I ran CalTracs w/ basic multi-leaf springs when I first tried them, but I pulled the SS springs off first. Too many people had already complained about that combination. I eventually swapped to Calvert's mono-leafs, which did work better for me.
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2733319
01/15/20 12:13 PM
01/15/20 12:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went a 1.33 w/Rancho 5-ways in the rear and 90-10's up front...........
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2733329
01/15/20 12:31 PM
01/15/20 12:31 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Who says they didn't work? Move a little weight to the front and see what happens.
Grant
Re: Multi leaf springs and caltracs don’t work [Re: weedburner] #2733554
01/16/20 09:47 AM
01/16/20 09:47 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Can it work?..... Sure. Would it work even better with the proper spring ratio? There’s only one way to find that out.
Re: Multi leaf springs and caltracs don’t work [Re: StealthWedge67] #2733556
01/16/20 09:54 AM
01/16/20 09:54 AM
PA
moparacer Offline
moparacer  Offline
PA
Never fooled with SS springs but I can confirm that the XHD springs definitely aren't the best option with caltracs.
I have them on my 67 Barracuda and even with a slow 1.50 60 ft I still had to clamp the heck out of them to try to control the axle wrap.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Multi leaf springs and caltracs don’t work [Re: moparacer] #2733614
01/16/20 01:44 PM
01/16/20 01:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When I bought the Caltracs for my Duster 20+ years ago Travis specifically told me to not use them with SS springs.
Re: Multi leaf springs and caltracs don’t work [Re: moparacer] #2733632
01/16/20 02:29 PM
01/16/20 02:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you have the Calverts why mess with SS springs? Just use the stock spring. If it flexes too much add a leaf under the main or just clamp them. That’s like two people pulling the same spark plug.
Re: Multi leaf springs and caltracs don’t work [Re: cudaman1969] #2733636
01/16/20 02:34 PM
01/16/20 02:34 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This ^^^
So, what you are telling me is running SS springs with a pinion snubber & Calvert bars at the same time wont make my car dead hook in a mud puddle LOL smile
Re: Multi leaf springs and caltracs don’t work [Re: CSK] #2733659
01/16/20 03:26 PM
01/16/20 03:26 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
This ^^^
The Mopar Performance Chassis Manual doesn't mention Cal-Tracs so, obviously, they don't work... grin
'63 Dodge 330
11.19 @ 121 mph
Re: Multi leaf springs and caltracs don’t work [Re: GY3] #2733674
01/16/20 04:16 PM
01/16/20 04:16 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I started with CalTraks and stock leafs with the bottom removed now it has the mono's and double adjustable strange shocks works for me...60's with CT's and stock springs was 1.51, now 1.43 with MSD Grid traction control killing 14* for 2 seconds it is 1.43 60', and that was in 55* weather and cold track. Early on I did experiment with SS springs and was way to stiff, wit & without CT's.
Re: Multi leaf springs and caltracs don’t work [Re: 1980volare] #2733694
01/16/20 05:58 PM
01/16/20 05:58 PM
AndyF Offline
AndyF  Offline
I learned a long time ago that on Moparts saying something works or doesn't work is meaningless. Some people's definition of working is really lax. I've seen stuff posted that I'd never run on a car and the poster says "oh yeah, it works great".
Re: Multi leaf springs and caltracs don’t work [Re: Keith Richards] #2733708
01/16/20 06:47 PM
01/16/20 06:47 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
what front tires are on your car in that pic of the underside of your car?
Re: Multi leaf springs and caltracs don’t work [Re: Keith Richards] #2733714
01/16/20 07:04 PM
01/16/20 07:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Move your shocks straight up and down and watch the 60's drop even more.....
Re: Multi leaf springs and caltracs don’t work [Re: krautrock] #2733742
01/16/20 08:48 PM
01/16/20 08:48 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
M/T ET Front
Re: Multi leaf springs and caltracs don’t work [Re: Thumperdart] #2733743
01/16/20 08:48 PM
01/16/20 08:48 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
We built a new upper bracket that moves the upper shock mount and makes the shock have just a few degrees of angle vs. the near 45° factory angle. Was, honestly, really surprised at how well it works!
'63 Dodge 330
11.19 @ 121 mph
