Which fuel pump? #2708871
10/21/19 01:38 PM
10/21/19 01:38 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Trying to finish up my 400/470 build and have a fuel pump question. I have two fuel pumps in my stash of parts to choose from. One is a Holley 12-440-11 that is rated at 110 gph and 6.5-8 psi. The other is a Carter M6903 rated at 120 gph and 6-7.5 psi. Which pump would you choose for my application?
Re: Which fuel pump? [Re: 440mopar] #2708890
10/21/19 02:37 PM
10/21/19 02:37 PM
AndyF Offline
AndyF  Offline
If they both work then I'd say it doesn't matter.
Re: Which fuel pump? [Re: AndyF] #2708953
10/21/19 06:39 PM
10/21/19 06:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW from my perspective I have NEVER heard anyone say man I wish I had less fuel pump. IMO if you EVER plan to build more power why not just start with a bigger/better pump to begin with. If its a budget deal then I get it otherwise lots of BETTER options out there
Re: Which fuel pump? [Re: Al_Alguire] #2708967
10/21/19 07:05 PM
10/21/19 07:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Either one should be fine for a street/strip deal, have used both and an Edelbrock equivalent.
Probably gonna need a regulator so you don't blow through the needle & seat, especially on a Carter or Eddy carb.
Re: Which fuel pump? [Re: topside] #2708976
10/21/19 07:15 PM
10/21/19 07:15 PM
AZ
squirrel Offline
squirrel  Offline
AZ
I've been running Holley Blue pumps for years, feeding blown big blocks, without too many problems. I do keep a spare in the trunk when I go on a road trip, but they usually last 5 to 15 years. They do make noise...adding good rubber mounting pads instead of what it comes with, will help. Whether or not this is the right pump for you, I can't say.
Re: Which fuel pump? [Re: 440mopar] #2709027
10/21/19 09:36 PM
10/21/19 09:36 PM
My memory is not as good as it use to be whiney
Is the Carter you have the one that has screws holding the two halves together or is the upper and lower body crimp onto each other? If it Is the good two piece unit with the three valves inside use it twocents
I've never had a Carter carb. have issues with that pump with those pressures flooding, never shruggy
