B-Body Drums to Disc Conversion #2708682
10/20/19 10:04 PM
10/20/19 10:04 PM
Windsor ,Ca.
Keith Richards Offline OP
Windsor ,Ca.
It appears I am getting a certain '68 B-Body back and it runs low 10's at 130'ish so one upgrade it needs is pitching those front drums and maybe even the back at a later date. I did a search hear to see what kits people have had good luck with but found nothing and doing a search on the net came up with many many kits, most brands I have never heard of. I do probably want to go the heavier route with a street type kit as the car runs pump gas and it will see limited street duty as it did in the past eventually. So my question is what kits have you used and how do you like them?
Thanks, Keith
Re: B-Body Drums to Disc Conversion [Re: Keith Richards] #2708697
10/20/19 10:45 PM
10/20/19 10:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My car is gets a lot of street miles and see's the track as often as possible. I used the Wilwood Pro-Street kit with vented rotors. I absolutely love the way they work and the ease of install. They bolted right to the drum spindle, too.
I've done a couple of 130 mph passes and it comes down from those with ease. Car is 3,600+ lbs. with me.
'63 Dodge 330
11.19 @ 121 mph
10.40 @ 130mph with a 200 shot of nitrous. 6.48 @ 105mph in the 1/8th. 1.37 60 ft.
Re: B-Body Drums to Disc Conversion [Re: GY3] #2708701
10/20/19 10:50 PM
10/20/19 10:50 PM
Windsor ,Ca.
Windsor ,Ca.
Thanks GY3, That is the brand and kit I was thinking as well, I am 3600# with me in the car as well.............. up
Just got to get the car here and make sure the current wheels fit around the calipers per there site, they are narrowed
stock looking steel wheels to replicate a 69.5 RR 6 pack car.
Re: B-Body Drums to Disc Conversion [Re: Keith Richards] #2708724
10/21/19 12:06 AM
10/21/19 12:06 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
I have been running the SSBC front brakes since 2007 , when I bought and imported the Plymouth . Had 10"rear drums , were fine till I started running 128+ . Now have rear discs , generic kit using Cadillac type calipers with handbrake , Metric GM caliper . Stops fine without fade now . No power booster .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80
Power by Tex's Automotive
Re: B-Body Drums to Disc Conversion [Re: tex013] #2708770
10/21/19 08:51 AM
10/21/19 08:51 AM
moparx Offline
moparx  Offline
what master cylinder bore, pedal ratio, and the diameter of the metric calipers ?
TIA tex.
beer
Re: B-Body Drums to Disc Conversion [Re: Keith Richards] #2708820
10/21/19 11:46 AM
10/21/19 11:46 AM
AndyF Offline
AndyF  Offline
Doctor Diff has everything you need for a disc conversion.
Re: B-Body Drums to Disc Conversion [Re: GY3] #2708824
10/21/19 11:49 AM
10/21/19 11:49 AM
fridley, minnesota
W
willie_68coronet Offline
W
fridley, minnesota
I'm looking at those also. Which diameter rotors did you get? 12 inch or?
Bloodgeon Mobile, '68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
Great customer service from: DominicThumper Carbs, B3 racing engines, A-1 torque converter's, Quick Performance
Re: B-Body Drums to Disc Conversion [Re: willie_68coronet] #2708919
10/21/19 04:10 PM
10/21/19 04:10 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
8
I honestly don't recall off the top of my head, but 10.7" sounds correct? Bought them at least 6 years ago...
'63 Dodge 330
11.19 @ 121 mph
Re: B-Body Drums to Disc Conversion [Re: moparx] #2708925
10/21/19 04:38 PM
10/21/19 04:38 PM
Sydney,Australia
Sydney,Australia
TIA tex.
beer
Ok ,
master cylinder is the 1 supplied by SSBC with the front brake kit , I am pretty sure it is 1" I ran it with factory booster and now without booster .
Has standard factory pedal ratio .
The caliper is iron and I had to slightly clearance it to run my 10"wide rims , ok with 8's
Caliper :
https://www.circletracksupply.com/g...ar-disc-kits-on-pick-up-trucks-cars.html
Similar kit:
https://www.performanceonline.com/M...-dana-60-Rear-Disc-Brake-Conversion-Kit/
This looks like the kit I got :
https://www.classicindustries.com/product/mp500551.html
I did have some spacer plates cut ro replicate the thickness of the drum backing plate to keep offset correct and bearings/seals in correct position . The POL kit and MasterPower kits have this supplied if I understand correctly , but be aware of this .
Andy is correct Cass (DRDiff) does have everything . He like a few others now use a mustang/ford rear caliper and a slightly smaller rotor . Cost of currency conversion plus freight stopped me buying these . Got my kit local unused for $400.00 . Seller showed me they were available , he bought them , on ebay
Tex
New best MPH 130.32
Re: B-Body Drums to Disc Conversion [Re: AndyF] #2709048
10/21/19 10:42 PM
10/21/19 10:42 PM
Windsor ,Ca.
Windsor ,Ca.
I'll look into that, Doctor Diff built the Dana 60 for me that's in the car still, back in about '06 or 7.
Re: B-Body Drums to Disc Conversion [Re: tex013] #2709175
10/22/19 12:52 PM
10/22/19 12:52 PM
moparx Offline
moparx  Offline
thanks tex. up
beer
tail lites
by GVH. 06/05/20 10:29 PM
SB deck to head dowel pin sizing?
by Diplomat360. 06/05/20 08:26 PM
Road race ramcharger render
by SRT6776. 06/05/20 07:40 PM
Anyone using Race Ramp's Wheel Cribs?
by David1971. 06/05/20 07:01 PM
Moparts Recent Posts
Proform distributor, yeah I know...
by Jim_Lusk. 06/06/20 12:31 AM
Sealing crankcase for vacuum
by Chargerfan68. 06/05/20 11:48 PM
Chevelle board? A question on the 396/402
by AndyF. 06/05/20 11:40 PM
new SFT for the 511
by mopar dave. 06/05/20 11:25 PM
