Correction factor and tuning question
#2708424
10/19/19 09:44 PM
10/19/19 09:44 PM
Posts: 820 New York, USA
Chargerfan68
New York, USA
I went to the track Friday and got a few runs in. I did 2 runs with exactly the same tune, and then after looking at the plugs, i jetted up slightly for the last 2 runs.
1050 dominator - 89 pri/ 96 sec. Run1: 11.06 @ 123.98. 1.544 60 ft Run 2: 10.93 @ 124.05. 1.525 60 ft
91 pri/96 sec Run 3: 11.07 @ 124.48. 1.604 60 ft Run 4: 10.90 @ 124.18. 1.500 60 ft
After correcting for density altitude, the 1st 2 runs correct to faster mph than the last 2 runs. so, my jetting change with the weather made the car pick up. But, in theory, it actually went slower with those changes. Not sure i fully understand what happened.
Re: Correction factor and tuning question
[Re: Chargerfan68]
#2708532
10/20/19 12:03 PM
10/20/19 12:03 PM
Posts: 33,796 Bend,OR USA
Cab_Burge
After correcting for density altitude, the 1st 2 runs correct to faster mph than the last 2 runs. so, my jetting change with the weather made the car pick up. But, in theory, it actually went slower with those changes. Not sure i fully understand what happened. Theory on many things affecting racing of all types is just that, theory. That being said stick with the basics like what the spark plug looks like and what the time slip says from your changes  Don't worry about maxing out the tune with theory involved and worry about why you weren't able to match the theory results  Run 3 looks like it spun the tires and then went faster every where else on the track
[Re: Cab_Burge]
#2708540
10/20/19 12:53 PM
10/20/19 12:53 PM
Posts: 12,509 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Not what you’re asking.......
I assume this is the stick car?
Looks like you’re giving up something in the middle. My friends stocker(4 speed) will ET slightly better than that 10.90 with slightly less mph than your 124....... and a very similar 60’ to your 1.50.
The moroso chart shows 124 is good for a 10.69.
With the small motor in the car he’s gone 10.80@123.
Run #3....... a bit of tire spin often shows up as a higher trap speed.
[Re: Cab_Burge]
#2708583
10/20/19 02:25 PM
10/20/19 02:25 PM
Chargerfan68
New York, USA
Cab,
I saw films of the 1st and last runs. The first run dead hooked. No tire spin at all. And the last run made 1 revolution and hooked which is ideal. I think thats why it 60 ft better. I do have an adjustable softlok in there to dial in some slip at the gear changes with centrifugal weight. The 3rd run i had clutch slippage at all gear changes according to graph. Shift recovery rpm was way higher rpm than normal. Not sure how i ended up with mph in 8th and 1/4 with what i saw on graph.
[Re: fast68plymouth]
#2708584
10/20/19 02:32 PM
10/20/19 02:32 PM
Chargerfan68
New York, USA
Dwayne,
Yes, this is the stick car with the M1 dominator manifold replacing the Victor. The M1 is without the 1-1/2” open tapered spacer i ran on the Victor. Also, i put on the flat stock looking fiberglass hood replacing the 4” sixpack scoop fresh air hood. I just radiused the upper plenum area and portmatched to the heads. Old setup usually ran 10.80’s at 126 mph. So i lost about a tenth and about 1-1/2 mph with this change.
But, that is with 4 runs with this setup, comparing to about 50 or so runs of tuning with the older setup
[Re: Chargerfan68]
#2708588
10/20/19 02:50 PM
10/20/19 02:50 PM
fast68plymouth
So. Burlington, Vt.
You had to know it was going to lose something. It’s less difference than I would have expected.
#2708648
10/20/19 07:04 PM
10/20/19 07:04 PM
Posts: 3,964 Prospect, PA
BSB67
Prospect, PA
Run #3....... a bit of tire spin often shows up as a higher trap speed. That has been my experience too
