Re: WHAT STARTER ? [Re: Sammy] #2708850
10/21/19 12:47 PM
10/21/19 12:47 PM
Originally Posted by Sammy
Originally Posted by RapidRobert
On the stock car it would get cranky when hot. I started cranking it THEN switching on the ign while cranking & that took care of it. Ground your coil wire & try it & see if that takes care of it
Can you explain what coil wire do you ground? confused
the large coil to dist wire, I hold the dist end 1/4" from the intake or similar ground & have someone crank it. pulling the ECU pentastar connector will do the same thing, then crank it EDIT seperating the dist pickup zigzag connector would be the easiest & no helper needed if seperating one of these connectors
Re: WHAT STARTER ? [Re: Sammy] #2709060
10/22/19 12:49 AM
10/22/19 12:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use a switch on the 12V+ wire to disable the ignition. Not on the ground wire. I actually have 2 switches on the same circuit, but one is hidden.
