62 B-body coil spring trans mount... #2707895
10/18/19 12:58 AM
10/18/19 12:58 AM
ky hills
thehemikid Offline OP
ky hills
The other trans mount thread finally reminded me to ask this question. I've had this Dart 330 since 92,
and thought it was a little odd when I first saw it then, but hadn't made it a point to research it or look under other 62's to check.
Though I have other 62's, they have the usual trans mounts.
Question. Was there an early coil spring trany mount in 62? This thing has always looked factory to me.
It's not pilot car early VIN #,... but it's in the low 500's.
Edit: Dang pic is upside down,... try'n fix.
Edit II: flipped the pic & loaded and still upside down. So be it,... I'm done. Lol.
Re: 62 B-body coil spring trans mount... [Re: thehemikid] #2707904
10/18/19 03:13 AM
10/18/19 03:13 AM
That looks like it was made, but not from the factory down twocents
Re: 62 B-body coil spring trans mount... [Re: Cab_Burge] #2707968
10/18/19 09:54 AM
10/18/19 09:54 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
That was the type that was on my 1962 Plymouth when I bought it. The car was 5 years old at the time and was a July build.
Re: 62 B-body coil spring trans mount... [Re: thehemikid] #2707976
10/18/19 10:21 AM
10/18/19 10:21 AM
Trumussia
jcc Offline
jcc  Offline
Trumussia
Never seen that before.
I wonder what was the intended purpose was vs rubber?
Not knowing the actual design, a coil only resists motion effectively one direction, seems odd to me.
"Respect and Contempt are best served when justly earned"
Re: 62 B-body coil spring trans mount... [Re: jcc] #2708030
10/18/19 11:48 AM
10/18/19 11:48 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Same setup as on my 64 300. there is an upper mount that bolts to the trans and seats the top of the coil spring. the bottom of the coil spring seatds on that mount and there is a thru bolt that slides thru the lower bracket and screws into the trans mount thru the center of the coil spring.
On my 64 the auto trans bracket was not the same as the manual trans bracket.
Re: 62 B-body coil spring trans mount... [Re: thehemikid] #2708048
10/18/19 12:41 PM
10/18/19 12:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'62 B-bodies used both the spring mount and the traditional one-piece insulator. Spring mount was usually used with the 318 and the one-piece with the Wedge and the /6.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
Re: 62 B-body coil spring trans mount... [Re: John_Kunkel] #2708064
10/18/19 12:53 PM
10/18/19 12:53 PM
Niles , Ohio
therocks Offline
Its Lost
therocks  Offline
Its Lost
Niles , Ohio
Looks like the one that was in my kids 62 300.Was a strange setup.Steve at Imperial Services sent him all the pieces free.Then when he change to modern TF he IIRC used the same setup.Rocky
Chrysler Firepower
Re: 62 B-body coil spring trans mount... [Re: therocks] #2708127
10/18/19 03:52 PM
10/18/19 03:52 PM
ky hills
ky hills
Thanks Sniper for the flip.
Thanks guys and John for the print, thought it looked factory. Looks like mine may've been a 318 car.
It had a 440, with STR intake w/ 6bbl lid and carbs when I traded a tube chassis s/b Duster for it.
tail lites
by GVH. 06/05/20 10:29 PM
SB deck to head dowel pin sizing?
by Diplomat360. 06/05/20 08:26 PM
Road race ramcharger render
by SRT6776. 06/05/20 07:40 PM
Anyone using Race Ramp's Wheel Cribs?
by David1971. 06/05/20 07:01 PM
Moparts Recent Posts
Proform distributor, yeah I know...
by Jim_Lusk. 06/06/20 12:31 AM
Sealing crankcase for vacuum
by Chargerfan68. 06/05/20 11:48 PM
Chevelle board? A question on the 396/402
by AndyF. 06/05/20 11:40 PM
new SFT for the 511
by mopar dave. 06/05/20 11:25 PM
