"Head rest" with low back buckets?
#2707427
10/16/19 10:32 PM
10/16/19 10:32 PM
Posts: 4,651 Wichita
GY3
Wichita
Let me preface this by saying I've been teched at 5 different tracks with this car. Car has all the safety equipment to run to 10.00...or so I thought!
We had a different guy at our local track this weekend (big Superstock race) and said I needed a head rest or pad mounted to the rollbar?!
The car has Superstock/A100 style fixed mount seats. I really hate to do this as it is a street car and gets used as one OFTEN! I honestly hate having the rollbar in the car but had one put in 2 years ago. This would make it an even bigger PITA to get into the back seat.
Re: "Head rest" with low back buckets?
[Re: jcc]
#2707433
10/16/19 10:48 PM
10/16/19 10:48 PM
GY3
Wichita
Sorry, you'll get no sympathy from me, now or when break your neck, to be blunt. Not asking for sympathy now or ever or your opinion for that matter. Asking if it is requirement from 11.49 down to 10.0?
[Re: Pacnorthcuda]
#2707438
10/16/19 11:03 PM
10/16/19 11:03 PM
GY3
Wichita
Thanks for the link as I had never seen nor heard of this before!
[Re: GY3]
#2707442
10/16/19 11:24 PM
10/16/19 11:24 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Yes, a headrest is required with the roll bar and low-back seats. I’ll also let you know that it would appear your door bars are not technically legal either. I did my door bars very similarly; they have been accepted by tech at my my track. At the D6 ET Finals this year however, I passed tech but then the NHRA tech director tracked me down in the pits to go over the rules with me. He mentioned my door bar and the lack of a headrest. The door bar must cross your arm above the elbow when your hand is on the wheel. He was real good about it, truly coming across more as helping me than anything. But I get the feeling if I show up at the Divisional next year with the same configuration, I may get bounced (???).
[Re: StealthWedge67]
#2707447
10/16/19 11:54 PM
10/16/19 11:54 PM
Posts: 1,263 New York, USA
Chargerfan68
New York, USA
How about mounting a removable head pad from the bar. This way you could remove it when you want. Also, just as a safety concern for you, if your shoulders are higher than the top of that bucket seat, i feel there is a possibility of severely compressing your back, God forbid, in a situation. Not picking, you have a world class car there.
[Re: Pacnorthcuda]
#2707450
10/17/19 12:21 AM
10/17/19 12:21 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
[Re: topside]
#2707489
10/17/19 04:55 AM
10/17/19 04:55 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
I have a flat bar bolts vertically between taxi bar and top of hoop . Has a padded plate with threaded rod mount horizontally from this . Passes local IHRA and ANDRA tech . I remove it on the street , factory bench seat .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2707490
10/17/19 05:22 AM
10/17/19 05:22 AM
Posts: 9,791 MI, usa
dvw
MI, usa
Its easy. Attach tube to the top hoop. Then attach a pad to it. Look close at the pass seat you'll see that the seats are braced as well. Doug
[Re: dvw]
#2707498
10/17/19 07:22 AM
10/17/19 07:22 AM
GY3
Wichita
I'm well aware of the door bars nof being "technically" legal but the local chassis shop that built it said they do a lot of street cars that way and tech never says anything. That has never been brought up by any inspector either.
Looks like I need to fab up something.
[Re: GY3]
#2707500
10/17/19 07:33 AM
10/17/19 07:33 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I need to do the same thing. Although I made it through NHRA tech at an NHRA track by an NHRA official I know it needs one. He never said a word about my head rest only about my my wrap around belts were done with no way to locate them on the bar. Two things I need to do to be legal for my ET.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Chargerfan68]
#2707529
10/17/19 09:22 AM
10/17/19 09:22 AM
Posts: 4,049 Mo.
racerx
Mo.
How about mounting a removable head pad from the bar. This way you could remove it when you want. Also, just as a safety concern for you, if your shoulders are higher than the top of that bucket seat, i feel there is a possibility of severely compressing your back, God forbid, in a situation. Not picking, you have a world class car there. This is what I was thinking , but will it be legal ? would it have to be welded permanently affixed to the cage.
[Re: GY3]
#2707548
10/17/19 09:58 AM
10/17/19 09:58 AM
Posts: 22,695 Bitopia
jcc
Bitopia
Sorry, you'll get no sympathy from me, now or when break your neck, to be blunt. Not asking for sympathy now or ever or your opinion for that matter. Asking if it is requirement from 11.49 down to 10.0? There is also no requirement that I need your permission to express my withholding of sympathy or expressing my opinion. Regardless, of any requirements, having no head rest today is considered by most rather short sighted and frankly dangerous, and any injuries incurred at the track with the lack of, effects everyone else to some degree negatively, and I see little reason to shy away from stating that, bluntly..
[Re: racerx]
#2707603
10/17/19 11:35 AM
10/17/19 11:35 AM
Posts: 1,229 In The Hills
jughed
In The Hills
How about mounting a removable head pad from the bar. This way you could remove it when you want. Also, just as a safety concern for you, if your shoulders are higher than the top of that bucket seat, i feel there is a possibility of severely compressing your back, God forbid, in a situation. Not picking, you have a world class car there. This is what I was thinking , but will it be legal ? would it have to be welded permanently affixed to the cage. This headrest can be unpinned...so i would say "no" to your question https://timmcamis.com/shop/headrest-kit.htmlI'll need one since A-100 lowback seats have replaced the Kirkeys in the street Dart for the retro look
