Tile experts #2707168
10/16/19 06:21 AM
10/16/19 06:21 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Wife and I are redoing our master bathroom and she wants a tile shower with a concrete floor. We plan on using the Kerdi schluter membrane for the walls, but I'm just not 100% sure on the floor since she just wants concrete instead of tile. We will be making our own shower base as the shower is a unique size. I'm thinking that I need to use the membrane on the walls and floor and get everything properly seal. Once that is done than pour the floor and let the concrete properly cure before sealing that with some type of sealer before moving on to tiling the walls. Is my process correct or how should it be done?
Re: Tile experts [Re: DusterKid] #2707207
10/16/19 09:40 AM
10/16/19 09:40 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
We had our bathroom remodeled last year including a new shower. I wanted the Schluter system but was told there are better, less expensive systems and we're very happy with the results. So they installed a concrete floor- properly sloped and a special drywall on the walls which gets taped as usual. Then the whole shower is painted with two or three coats of membrane. So the end result is a continuous membrane, not a "sheet membrane" with joints.
We also had a heated floor installed in the rest of the bathroom so no cold feet - ever !!
So I just re-read your post ... you do not want the membrane "below" the concrete - you want the membrane on top of the concrete. Would build a pool with the pool liner on the outside of the walls ?!?!
Re: Tile experts [Re: Stanton] #2707218
10/16/19 10:07 AM
10/16/19 10:07 AM
Keymar, MD
Keymar, MD
That's what has me a little confused is the floor. I need some type of waterproofing under the concrete to the subfloor, but not sure how exactly that should be done. I can't put the membrane on top of the concrete if she wants the floor to be finished concrete.
Re: Tile experts [Re: DusterKid] #2707220
10/16/19 10:11 AM
10/16/19 10:11 AM
Whoa-is-mia
srt Offline
srt  Offline
Whoa-is-mia
Best to locate drain, tar paper floor and walls, grout shaped to drain, manufactured liner system of choice up walls and over curb and a wire reinforced conc floor with proper curbed pan. I'd recommend getting the wire reinforcement epoxy coated. The walls can be mortar or pre-manufactured with tile and grout.I'd recommend caulking all the corners where wall meets wall or wall meets floor rather than grouting. Appropriate grout matching sealants should be available where you buy the grout.
Use tar paper on floors and walls to create a "cleavage" layer that allows the shower components to "move".
“Facts are stubborn things; and whatever may be our wishes, our inclinations, or the dictates of our passion, they cannot alter the state of facts and evidence.”
John Adams
Re: Tile experts [Re: DusterKid] #2707221
10/16/19 10:16 AM
10/16/19 10:16 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If you do a traditional concrete shower pan, it will be poured in two stages. The initial concrete pour on top of the sub-floor will have a slight pitch toward the drain Then the thick heavy rubber pan liner gets laid down on top of the first layer of concrete, and gets sandwiched into the floor strainer. Finally the second layer of concrete on top of the liner has a slightly steeper slope to the drain.
Then the wall membrane comes down and overlaps the top edge of the rubber pan liner, so any water that runs down the wall ends up inside the pan liner.
Re: Tile experts [Re: wingman] #2707252
10/16/19 11:54 AM
10/16/19 11:54 AM
west palm beach, florida
modelmakerinc Offline
IMO, you are asking for trouble down the road, find a good shower floor tile that she can live with and use the money saved on upgrades to something somewhere else in the house.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Tile experts [Re: DusterKid] #2707269
10/16/19 12:58 PM
10/16/19 12:58 PM
Charlotte, NC
Orange_Crush Offline
Belieber!
Belieber!
Charlotte, NC
I have used the Kerdi system a couple of times with very good results.
I lined a shower and an entire bathroom floor and 4 inches up the wall all the way around. I used the Schluter shower pan and curb as well as the Ditra on the floor as well. I was very happy with the results.
The system worked great with no leaks.
Just, whatever you do, make sure you follow the instruction TO THE LETTER! And, I didn't specify this last time I told someone to use this stuff, make sure that you put it on over a moisture resistant surface (green board, cement board, moisture resistant sheetrock, etc.). If you apply it over regular sheetrock, it''ll peel off and take the paper backing with it.
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Tile experts [Re: Orange_Crush] #2707286
10/16/19 02:27 PM
10/16/19 02:27 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
We just used one of these in ours so that we could get to a level entry without a curb. Grout should be going in today. We used a 48 x 48 cut down to our size of about 46 x 46. Dang shower pan was about $750 though. Reviews are good - hope it works!
https://us.wedi.de/product-systems/shower-and-wet-room-systems/shower-systems/fundo-ligno/
Re: Tile experts [Re: MoparKansas] #2707294
10/16/19 03:15 PM
10/16/19 03:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Y'all need to go reread what he's asking.
He want the Concrete to be the floor. As in that's what you will be standing on when showering. Can't put a membrane atop that.
Re: Tile experts [Re: Sniper] #2707549
10/17/19 10:02 AM
10/17/19 10:02 AM
Mardi Gras-Land
340SIX Offline
340SIX  Offline
Mardi Gras-Land
He wants
I read it. Also, This is what I did for 32 years.
A membrane under it going up will but the Cement will take time to dry always.
If he does this his Cement Floor will aways be wet to some extent.
In would also run as I did in my own home run a Membrane Behind the cement board walls I used USG 1/2. screwed with Epoxy Deck.
Floated all seams and taped floated them and used a commercial flexible mortar that was also used to set the tile.
100% of all 4 walls even in my guest bats are done this way even with tubs.
In case of a tornado from Hurracane it is the safest roonm in the house
Re: Tile experts [Re: Stanton] #2707563
10/17/19 10:28 AM
10/17/19 10:28 AM
Mardi Gras-Land
340SIX Offline
340SIX  Offline
Mardi Gras-Land
A few pics
Re: Tile experts [Re: 340SIX] #2707565
10/17/19 10:29 AM
10/17/19 10:29 AM
Mardi Gras-Land
340SIX Offline
340SIX  Offline
Mardi Gras-Land
Re: Tile experts [Re: 340SIX] #2707573
10/17/19 10:43 AM
10/17/19 10:43 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Originally Posted by 340SIX
A few pics
Man, if we wanted to look at pictures of you posting selfies in your bathroom mirror we'd be over on Yellowbullet. grin
Re: Tile experts [Re: wingman] #2707590
10/17/19 11:11 AM
10/17/19 11:11 AM
Mardi Gras-Land
340SIX Offline
340SIX  Offline
Mardi Gras-Land
A few pics
I will reflect on that.
Re: Tile experts [Re: 340SIX] #2707591
10/17/19 11:12 AM
10/17/19 11:12 AM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
Nice work, 340. DO you use some kind of tile spacing/leveling system, or do you just eyeball it?
I used to eyeball it, but I've been looking at the Raimondi (or similar) tile leveling system (like THIS) for my next job (I don't do this for a living). Do you have any experience with it?
Re: Tile experts [Re: Orange_Crush] #2707628
10/17/19 12:31 PM
10/17/19 12:31 PM
Mardi Gras-Land
340SIX Offline
340SIX  Offline
Mardi Gras-Land
Those will be fine but keep in mind that no material is 100% Stone as well as Porcelain and Ceramic so some synthetic or wood wedges will be needed as well.
When It comes down to it a Tape Measure and Level Pencils are ya best friend. Along with String.
Re: Tile experts [Re: 340SIX] #2707652
10/17/19 01:22 PM
10/17/19 01:22 PM
Western Md.
skicker Offline
Son of Doc Fiberglass
skicker  Offline
Western Md.
I found that if installing an accent band or feature in a design it worked best to install that item from a stringer...wood/metal...whatever...and then cut the corresponding tile as an infill to
complete the wall...
It worked well for this...everything stays laser straight...
69 Dart 12.32 at 109 mph...
72 Duster 11.66 at 113 mph...
70 Satellite 17's somewhere...
65 Coronet on the 5 year plan
65 Bel II still on the 10 year plan...
skickermotorsports...
Destroying perfectly good chit for 35 years and counting...
Re: Tile experts [Re: 340SIX] #2707660
10/17/19 01:53 PM
10/17/19 01:53 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
I get that. I've put down a lot of ceramic and porcelain, but when it comes to stone (or hand-cut tile), I hand it over to my wife, who can lay tile much better than I can and can eyeball grout joints and tile level like a pro. All the stuff I've done has been learned through experience (i.e. stupid mistakes) like my first tile job...a 12 x 15 kitchen in an old house. I decided the best idea was lay the tile against the wall first and work my way in! I'm figuring you can guess how THAT worked out.
