Page 3 of 7 1 2 3 4 5 6 7
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2706620
10/14/19 09:11 AM
10/14/19 09:11 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Originally Posted by mopar_man619
next I was in the market for a cable driven throttle body. bbk were kinda pricey and efisource was just releasing adapters to use a ls throttle body. I know I know.
heres link for adapter
https://www.efisource.com/wp/shop/gen-3-hemi-throttle-body-adapter/
and the throttle body is from warr performance. tb is 92mm and I believe the intake open is only 90mm or so. needs to be bored
Hey now NOTHING wrong with using the LS TB.....what the engine doesn't know won't hurt it.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: moparan619's Turbo Gen 3 Valiant [Re: Ray408G3Hemi] #2706698
10/14/19 01:06 PM
10/14/19 01:06 PM
IL
furious70 Offline
furious70  Offline
IL
I use a Ford 5.0 style BBK TB on my turbo 383. It has never once complained to me about the OEM origin, it's sucked up every bit of air that's gone through it.
The alt is going up above the turbo? Is there not room to put it over on the driver's side somewhere and still run a belt the right way for the waterpump?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: moparan619's Turbo Gen 3 Valiant [Re: furious70] #2707132
10/15/19 11:01 PM
10/15/19 11:01 PM
Springtown Pa
Springtown Pa
That's what I was wondering...but with the truck cover it might not be doable, the Auto(LX/Jeep) cover you can mount the alt over where the Air Compressor would go.
1996 Viper GTS
Re: moparan619's Turbo Gen 3 Valiant [Re: Ray408G3Hemi] #2707256
10/16/19 12:04 PM
10/16/19 12:04 PM
IL
furious70 Offline
furious70  Offline
IL
but on trucks it sits up there where the a/c sits on LA engine, right? He might need to use the little denso unit instead of the one native to the car.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: moparan619's Turbo Gen 3 Valiant [Re: Ray408G3Hemi] #2707471
10/17/19 02:28 AM
10/17/19 02:28 AM
San Diego, CA
mopar_man619 Offline OP
San Diego, CA
I hear that. my pockets would've known the difference thats fissure lol
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: moparan619's Turbo Gen 3 Valiant [Re: Ray408G3Hemi] #2707474
10/17/19 02:32 AM
10/17/19 02:32 AM
San Diego, CA
San Diego, CA
what I was going to do but my /6 k member and Schumacher mount set up don't allow much room.
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: furious70] #2707475
10/17/19 02:34 AM
10/17/19 02:34 AM
San Diego, CA
San Diego, CA
heres what im going for. and hopefully be able to miss the 3 inch downpipe
17621817_804013983107611_1702630286103996948_o.jpg17362913_803835119792164_9188008285107294779_n.jpg
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2707476
10/17/19 02:36 AM
10/17/19 02:36 AM
San Diego, CA
San Diego, CA
other examples of alternators with truck front covers and car intakes
15391017_10154769913677498_8904284745808595190_n.jpg15304069_338174529898726_2986468871090160534_o.jpg7361_1082690065105757_5690889136527204252_n.jpg
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2707478
10/17/19 02:41 AM
10/17/19 02:41 AM
San Diego, CA
San Diego, CA
intercooler came in
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2707480
10/17/19 02:44 AM
10/17/19 02:44 AM
San Diego, CA
San Diego, CA
44mm wastegate vs 60mm. the 60 I ordered when I ordered the turbo but its massive in an already crammed bay. going to try a single 44 then add another later if creep is a problem
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2707482
10/17/19 02:50 AM
10/17/19 02:50 AM
San Diego, CA
San Diego, CA
scored these deatschwerks 88lb injectors brand new off offer up for a deal I couldn't pass up.
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2707540
10/17/19 09:45 AM
10/17/19 09:45 AM
Springtown Pa
Springtown Pa
Sweet loving the detailed photos keep it up
1996 Viper GTS
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2719615
11/27/19 12:43 AM
11/27/19 12:43 AM
San Diego, CA
San Diego, CA
no hole in this one! yay!
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2719696
11/27/19 11:21 AM
11/27/19 11:21 AM
Springtown Pa
Springtown Pa
Keep it up looking forward to seeing this run.
1996 Viper GTS
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2719697
11/27/19 11:26 AM
11/27/19 11:26 AM
Springtown Pa
Springtown Pa
I've seen some BIG holes in these G3s, this was a Turbo 5.7 with a stock cast crank, it let go around 1000hp, #5&6 journal came out the side of the block. , the rear hole was cut to make it larger .front of the block was dissected.
1996 Viper GTS
Re: moparan619's Turbo Gen 3 Valiant [Re: Ray408G3Hemi] #2720293
11/29/19 05:47 PM
11/29/19 05:47 PM
San Diego, CA
San Diego, CA
1000hp on stock parts. can't be mad at that! ill be happy with 600 lol
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2720297
11/29/19 06:00 PM
11/29/19 06:00 PM
San Diego, CA
San Diego, CA
heads drilled and tapped for forward facing truck manifolds
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2720300
11/29/19 06:02 PM
11/29/19 06:02 PM
San Diego, CA
San Diego, CA
pulled mock up engine and trans. ready to paint and almost ready for engine to go in
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2720302
11/29/19 06:06 PM
11/29/19 06:06 PM
San Diego, CA
San Diego, CA
engine comp painted. mocking up gpa's kirkey
11.42@119
Re: moparan619's Turbo Gen 3 Valiant [Re: mopar_man619] #2720305
11/29/19 06:11 PM
11/29/19 06:11 PM
San Diego, CA
San Diego, CA
she's coming along! truck and car harmonic balancers are different fyi! was wondering why my belt wouldn't line up...
11.42@119
