Page 3 of 3 1 2 3
Re: Closer Towers - Line Spacing [Re: srt] #2706679
10/14/19 12:27 PM
10/14/19 12:27 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by srt
borate - this from wiki - Fire retardant Borate salts used in the past to fight wildfires have been found to sterilize the soil and be toxic to animals so are now prohibited. Newer retardants use ammonium sulfate or ammonium polyphosphate with attapulgite clay thickener or diammonium phosphate with a guar gum derivative thickener.
We were told it's similar to fertilizer.
Mmmmmmm. Cow 💩. I’m cool with that.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Closer Towers - Line Spacing [Re: pittsburghracer] #2707023
10/15/19 02:35 PM
10/15/19 02:35 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Fires are a natural part of things. That's how old, dead growth and debris and underbrush is eliminated.
Problem is when you "fight" fires and keep them from happening for years and years, the old, dead growth and debris and underbrush build up, adding more and more fuel.
So when the inevitable fire does finally happen it is much worse and more intense.
Re: Closer Towers - Line Spacing [Re: wingman] #2707039
10/15/19 03:49 PM
10/15/19 03:49 PM
Trumussia
jcc Offline
jcc  Offline
Trumussia
Fires might be a natural part, but on Fire Garbage trucks dumping their burning loads alongside of the road near brush/grasslands is not.
Next year, no energized power lines and no garbage trucks, that ought to fix things. biggrin
"Respect and Contempt are best served when justly earned"
Re: Closer Towers - Line Spacing [Re: jcc] #2707051
10/15/19 04:45 PM
10/15/19 04:45 PM
PA.
"Little"John
"Little"John
PA.
And no more barbecuing. Hard to believe someone would dump hot ashes in their garbage.
1970 Duster
6.143@110.85 mph
5.982@112.56 mph
9.42@138.27
Re: CA PSPS Power Outage [Re: a12rag] #2707064
10/15/19 05:12 PM
10/15/19 05:12 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Originally Posted by a12rag
So PG & E, declares bankruptcy last year when they were found liable for the big fires . . . . So now this year, the utility (whatever they are called now), decides to black out/de-energize power lines, so as to NOT have that liablity . . . . WOW !!! . . . sounds like the lawyers sure do run that state - if the distribution system were properly maintained - think trees trimmed or removed along rights of way of powerlines, AND infrastructure (think old poles replaced, overcurrent protective devices - relays, circuit breakers, etc) were maintained to SHUT OFF possible short circuits . . . then power would be on and risk would be at total minimum . . . however, the media takes what they get told from utility and give that information to everyone - no power, to protect you ! . . . PHHHHTTTTT . . . . . oh, I probably forgot the greenie weenies that say "You can't cut down trees" !!! . . . .
What has happened to this world in the last 4-6 years ?!?!?!? . . . .
Rant off . . . .
OOPS - sorry, one more thought . . . for those looking to plug in a portable generator and keep the fridge/freezer going, etc . . . . PLEASE PLEASE PLEASE - ENSURE YOU TURN YOUR MAIN BREAKER OFF !!!! . . . do not back feed into the grid !!!
Nobody here is buying PG&E's B.S. They are doing this to try and strong-arm the legislature into passing some liability-limits law for them. We should eminent domain that 'utility' and run it like Caltrans.
Trying to enjoy life!
Re: Closer Towers - Line Spacing [Re: wingman] #2707083
10/15/19 07:02 PM
10/15/19 07:02 PM
Phoenix, AZ
Jjs72D Offline
Jjs72D  Offline
Phoenix, AZ
You mean that "Natural Selection" works better?
I agree. The same principle applies to the many, many inferior people that have been protected by silly warning labels and frivolous lawsuits! If they were weeded out by natural selection, the rest of society wouldn't have so many idiots to contend with. There would be less traffic, less crime and fewer diseases.
Lower taxes too, I'd hope.
Re: Closer Towers - Line Spacing [Re: pittsburghracer] #2707088
10/15/19 07:28 PM
10/15/19 07:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I find it very easy to believe that somebody would do just that. People can be rock stupid at times...
Page 3 of 3 1 2 3
Hellcat throttle body adapter
by CJD AUTOMOTIVE. 06/04/20 06:10 PM
Nhra revised schedule -
by GomangoCuda. 06/04/20 05:38 PM
Chevelle board? A question on the 396/402
by jeff968. 06/04/20 05:35 PM
ebay collector cars
by antonellomopar. 06/04/20 05:23 PM
Moparts Recent Posts
The official Coronavirus thread
by 360view. 06/04/20 06:33 PM
Cam and crank sensors.
by MattW. 06/04/20 06:26 PM
by MR_P_BODY. 06/04/20 06:21 PM
by gtx6970. 06/04/20 06:16 PM
