Re: Help Degree Cam in Cincinnati
[Re: lockjaw-express]
#2706986
10/15/19 12:37 PM
10/15/19 12:37 PM
BradH
Would it be better in the long run if you spent the money on the tools to do the job and learned how to do it right yourself? Or am I misunderstanding the situation?
#2707019
10/15/19 02:12 PM
10/15/19 02:12 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I need someone to educate me, but do it for me...buying tools just to buy tools if I don’t know what I am doing is not on my list.
I will pay for someone’s help to dial it in
Mark Mark I did my first one 40 years ago following a Direct Connection book. Now there are DVD’s showing you how and better pictures in books to help you. If you watch someone do it you will not learn a damn thing. Trust me you can do it and by doing it yourself next time will be a cake walk. PS I’ve had lots of luck advancing them 4 degrees
#2707050
10/15/19 04:43 PM
10/15/19 04:43 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thank you Andy and others, however I would like to make sure I am right on the mark... I would just like some help, and I would just like someone local to help me.
Mark Wish I was closer Mark.
[Re: pittsburghracer]
#2707069
10/15/19 05:57 PM
10/15/19 05:57 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Mark Wish I was closer Mark. I do too!
#2707087
10/15/19 07:22 PM
10/15/19 07:22 PM
RapidRobert
You would need a piston stop ($10) & a degree wheel (fairly cheap) & a large one is better to work with but are $$$. there might be some utube vids on the procedure. #1 with the piston stop confirm the dampener slit is on TDC on the timing tab (or within 1 degree). EDIT you might search for someone local to come show you, it's a slighly twisted procedure (I had to read the procedure several times) but when you grasp it you'll have it & it is simple: How many degrees after TDC does the cam cyl #1 intake valve lobe reach max lift & I forgot you also need a dial indicator (clamp on or magnetic). MORE EDIT I just checked utube & there are some very good procedures on there
[Re: RapidRobert]
#2707097
10/15/19 08:21 PM
10/15/19 08:21 PM
Posts: 562 Ohio
lockjaw-express
Ohio
You would need a piston stop ($10) & a degree wheel (fairly cheap) & a large one is better to work with but are $$$. there might be some utube vids on the procedure. #1 with the piston stop confirm the dampener slit is on TDC on the timing tab (or within 1 degree). EDIT you might search for someone local to come show you, it's a slighly twisted procedure (I had to read the procedure several times) but when you grasp it you'll have it & it is simple: How many degrees after TDC does the cam cyl #1 intake valve lobe reach max lift & I forgot you also need a dial indicator (clamp on or magnetic). MORE EDIT I just checked utube & there are some very good procedures on there I have some things, but not the degree wheel...the engine is in the car. What I need is an EXPERT that will help me do it correctly, and I expect to pay that person Mark
[Re: ksj]
#2707118
10/15/19 10:01 PM
10/15/19 10:01 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Mark - I would be happy to help if you would like me to.
Mark
[Re: markz528]
#2707124
10/15/19 10:23 PM
10/15/19 10:23 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If any of you guys are interested in learning how to degree cams in or already do so I highly recommend this tool. It slides into the lifter bore and with a dial indicator installed on it makes this job so more easier, more consistent, and quicker. Christmas is coming, put it on your wish list. https://www.summitracing.com/parts/cca-4926/overview/
[Re: markz528]
#2707127
10/15/19 10:47 PM
10/15/19 10:47 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Mark Mark, That would be GREAT! I will have my cam on Friday or Monday next week, so maybe by the next weekend? Here is my number to call me. (513) 515-5418 Regards, Mark
#2707129
10/15/19 10:56 PM
10/15/19 10:56 PM
markz528
Morrow, OH
Mark Mark, That would be GREAT! I will have my cam on Friday or Monday next week, so maybe by the next weekend? Here is my number to call me. (513) 515-5418 Regards, Mark Mark - will call you tomorrow. Traveling home tomorrow during the day.
[Re: markz528]
#2707139
10/15/19 11:32 PM
10/15/19 11:32 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Mark Mark, That would be GREAT! I will have my cam on Friday or Monday next week, so maybe by the next weekend? Here is my number to call me. (513) 515-5418 Regards, Mark Mark - will call you tomorrow. Traveling home tomorrow during the day. GREAT! Thanks!
#2710295
10/27/19 01:38 AM
10/27/19 01:38 AM
Posts: 562 Ohio
lockjaw-express
Ohio
Mark Mark, That would be GREAT! I will have my cam on Friday or Monday next week, so maybe by the next weekend? Here is my number to call me. (513) 515-5418 Regards, Mark Mark - will call you tomorrow. Traveling home tomorrow during the day. GREAT! Thanks! Mark Came over tonight to help me degree my New Dwayne Porter Camshaft, and the Jesel was 5 degrees (retarded) off from where the dot to dot is...The intake centerline was 115*. and that was 5 degrees off, then to add 2* advance, to bring it to 113* at Dwaynes spec. Not quite one tooth retarded, but almost. Boy, did I learn a lot from Mark. He was a real life saver on this! Thank you Mark! Mark
