727 Trans support info needed #2706932
10/15/19 09:32 AM
10/15/19 09:32 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
We have a 71 RR that has no support, (bolt in)
Is there a difference between the 4 speed and auto support besides the
cushion?
Also, can someone tell me what crossmembers will work in our application, i.e.
years/bodies.
Thanks in advance....Joe
Re: 727 Trans support info needed [Re: jlatessa] #2707232
10/16/19 10:57 AM
10/16/19 10:57 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Found my answer, only difference IS in the isolator.
Joe
Re: 727 Trans support info needed [Re: jlatessa] #2707264
10/16/19 12:32 PM
10/16/19 12:32 PM
moparx Offline
moparx  Offline
then you can bolt up an isolater according to the crossmember you are using ?
beer
Re: 727 Trans support info needed [Re: moparx] #2707265
10/16/19 12:39 PM
10/16/19 12:39 PM
IMGTX Offline
IMGTX  Offline
71 to 72 B Bodies and all e bodies use the same support. Manual and Auto are the same also. I think the 73 later B bodies are the same too but I could be wrong.
The older B bodies used a box shaped mount instead of the spool mount and the support must match the mount.
I'm a little fuzzy on it but I think some years used a different support for Auto vs manual. If so that ended with the spool mounts.
Re: 727 Trans support info needed [Re: moparx] #2707320
10/16/19 04:48 PM
10/16/19 04:48 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Yes MOPARX, it's the same support for both transmissions, just a different isolator.
I questioned Brewers and got the skinny from them,
thanks Brewers!
Joe
Re: 727 Trans support info needed [Re: jlatessa] #2707578
10/17/19 10:47 AM
10/17/19 10:47 AM
moparx Offline
moparx  Offline
thanks J !
you have added some info into an old guy's cobweb storage.
now, if i can just remember if, and when, it's ever needed. laugh2
beer
