Been messing with several different AFB from different manufacture and comparing to the Hemi carbs. One thing that struck me is how different many AFB carbs even across manufacturer. Buick/Cad/Chevy/Pontiac all had different approaches on Throttle bore sizes, main and primary venture size and design, etc... Even comparing GM Big Block they all seemed to take a different approach using the same basic AFB design. I understand carb basics, and even some of the theory, but have not been able to find any info on why so many subtle difference and what were the engineers after?
First, the hemi stayed relatively the same especially manifold, heads and exhaust. So why all the changes across year with jetting. They started with big stagger on Front carb secondary and ended up with smaller stagger on rear carb secondary? They had to use deflector tabs which ultimately should have an adverse effect on CFM. Was the manifold that bad as far as even fuel distribution to all the cylinders?
The other interesting item is the shorter primary main venture that they seemed to use. It was sunk into the carb body for the hemi. They then used a larger body primary venture with a long booster body. Most of the other manufactures did not do this for their Big block and or dual quad motors. The main venture was fuller and that resulted in a shorter primary venture. What is the difference in carb performance?
I understand Venturi diameter and how it effects flow and pressure, but could not find any info on venturi length and it's effect. Picture shows a hemi front against a Pontiac 4 barrel AFB. You can see the difference in primary side main venturi and also primary (booster) venturi. Both are rated the same for Throttle area and Venturi area. Even the internal machining was different on the Pontiac. Same diameter but after the venturi they opened the booster more.
Anyone heavy into racing these Carter's in the stock class back in the day? What approach for a basic stock Hemi motor did you take? Thanks
