Which gearsets are quieter nowadays, D60 or 8 3/4?
#2706706
10/14/19 01:25 PM
10/14/19 01:25 PM
Posts: 11,999 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have had 8 3/4s under my street/strip cars forever. I have only busted one or two over the years so overall durability in not an issue. My problem is that they are always quiet at first, but man do they get noisy after a few years. The 3.91s I have in there now have gotten so loud that I can hardly hear the radio over them. I pulled them out last winter and checked everything and it all looked good. I can usually get 4 or 5 years (less than 10,000 miles) before they get unbearably noisy. That is the situation now.
Now I have a truck D60 that I can cut down, flange and set-up for the Cuda. It will obviously cost more to do that than replace the ring and pinion in the present 8 3/4. The only real reason I would go to the time and expense of changing over to the Dana is if it were to stay quiet.
I hit the track with Drag Radials 2 or 3 times a year if that matters. Auto trans, 1.5/1.6 60's, 3,900lbs.
So my question is: are the gear sets for the Danas any quieter than the gear sets for the 8 3/4s over time? Any help and direction here would be appreciated. I have to do something with the rear gears this winter. I just need to decide which is the better route to quiet rear gears over the years.
Master, again and still
Re: Which gearsets are quieter nowadays, D60 or 8 3/4?
[Re: DaveRS23]
#2706783
10/14/19 06:38 PM
10/14/19 06:38 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Your having luck I never had, none of the good 8 3/4 gear sets I had set up by a good shop never made noise, even after cracking the outer edge of the ring gear teeth on every tooth I would pull them on the race cars after 100 runs to check them, I had one tooth corner break off at the track in the burn out box and ruin that day. None broken while driving them after that by replacing them before the corners broke off I bent the heck out of the last 8 3/4 housing I had cut down to put in my old pump gas Duster street car that was half fast, 10.0 at 134. MPH corked up on pump Oregon 91 octane swill motor only with the air cleaner on I replaced it with a cut down Dana 60 out of a pickup and the car pushed so much easier after that I wish I had put a good Dana 60 in it to start with I had tried 4 different gear sets in that 8 3/4 before breaking the ladder bar tabs off of the housing at Woodburn drag strip in around 2008 or 2009, 3:73,3:91, 3:91,4:10 and the final set of 4.30. That stupid car ran almost the same ET and MPH no matter what gear set was in the rear end I cracked the corners on all of the ring gears also That rear end had a set of Strange 35 spline axles and a strange Engr. 35 spline spool in the 8 3/4 since day one also The stock set of Dana 60 4.10 gears are still in that car going strong, same thing on the stock Dana 4.56 gear set in my current S/P car I had the rear cover off last year after a bunch of runs and they looked great, no noise or ring gear cracks IHThs
[Re: DaveRS23]
#2706940
10/15/19 10:17 AM
10/15/19 10:17 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
You are not alone.
Every 8.75 diff I've ever owned roared at highway speed. Probably pinion bearing, I just live with it because I drive them so little, but hate it just as much as you do.
I've been waiting for someone to upload a Youtube video of how to do a full re-build of the 8.75 so I can know how to do one, but still no one has done it.
The 9.25's in the Rams are only a bit better but, same thing: pinion bearing replacement is required reading for a Dodge Owner.
The Dana that was in my diesels I didn't own long enough to comment, but I sure don't hear the 2500/3500 Owners complaining about them, so you might be on the right track with going the Dana route.
Mo' Farts
Moderated by "tbagger".
[Re: GoodysGotaCuda]
#2707202
10/16/19 09:07 AM
10/16/19 09:07 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have Motive [Richmond] gears in my 489 case and however I set them up is too noisy for my liking. They're quiet as long as I am accelerating or under load but begin to get quite loud on light load/decel.
I may have to go back into the diff this Winter and try to make some adjustments. Sounds similar to mine. Quiet under load and under full decel. But VERY noisy in between. Makes cruising a pain and makes me want to just race all the time.
[Re: moparx]
#2707347
10/16/19 07:00 PM
10/16/19 07:00 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Real dana spicer gears set up properly are as quiet as a Lincoln or Cadillac...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2707352
10/16/19 07:10 PM
10/16/19 07:10 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Real dana spicer gears set up properly are as quiet as a Lincoln or Cadillac... Okay. Now where do I get them?
