RacePak Dash vs. Holley Stand Alone Dash #2706472
10/13/19 07:24 PM
10/13/19 07:24 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Anyone try the Holley stand alone. Figured the software and such would be easy to use, but it seems rather new.
Looking to put somthing in my Street Strip car....
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: Dragula] #2706475
10/13/19 07:36 PM
10/13/19 07:36 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Holley 7" dash, it can be used stand alone or with Holley EFI, I have mine with EFI, it is AWESOME, you can take a blank screen & build a dash like you want & need. the ONLY thing is I have to wear my cheater reading glasses because I have so much on the dash.
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: CSK] #2706476
10/13/19 07:37 PM
10/13/19 07:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: Dragula] #2706485
10/13/19 08:23 PM
10/13/19 08:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Do you have anything now? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: hemi-itis] #2706508
10/13/19 09:22 PM
10/13/19 09:22 PM
Dragula Offline OP
Dragula  Offline OP
Monster Tach,Sun pro oil pressure, water temp, and volt meter with a GoPro.....and an AFR gauge....How's that?
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: Dragula] #2706541
10/13/19 10:28 PM
10/13/19 10:28 PM
AndyF Offline
AndyF  Offline
I have the 7" digital dash in my Coronet and the 12.8 inch Pro Dash in my Duster.
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: AndyF] #2706604
10/14/19 07:30 AM
10/14/19 07:30 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Holley Dashes look super nice! The only issue I have with any dash like that is trusting the tachometer. I like an analog one so much I am not sure I could shift off of a dash. I don't do well with a shift light either but that is just me.
68 Barracuda Formula S 340
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: Bad340fish] #2706676
10/14/19 12:08 PM
10/14/19 12:08 PM
hemi-itis Offline
hemi-itis  Offline
I took the monster tack off the top of the dash when I put a new dash pad on,replaced it with a shift light.
Does the Holley deal data log? I spent close to $3k for the race pak logger dash.Picked up a 1/2 second just by seeing my AFR. I also found the the wall with IAT where the power goes flat!
Time for am intercooler boogie
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: hemi-itis] #2706682
10/14/19 12:31 PM
10/14/19 12:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Yes the Holley Data Logs.
Re: RacePak Dash vs. Hplley Stand Alone Dash [Re: CSK] #2706850
10/14/19 10:15 PM
10/14/19 10:15 PM
hemi-itis Offline
hemi-itis  Offline
If your using Holley EFI it's a no brainer. Still need to install all the sensors.I do like the holly dash better than the race pak. popcorn
